Which enclosure will get lower? Ported @25Hz or T-line @34Hz - Car Audio Classifieds!
Old 05-22-2012, 08:19 AM
0/11 ssssssss5
Cool Which enclosure will get lower? Ported @25Hz or T-line @34Hz
Which will hit lower notes? Four 10" subs with a fs of 25 Hz in a ported enclosure tuned to 25 Hz? Or two 12" subs with a fs of 34 Hz in a transmission line enclosure tuned to 34 Hz?
Both options will be receiving 2000 watts continuous power @ 1 ohm from a Mmats 2000.1d. The four tens are Image Dynamics IDQ v3 and the two twelves are the older Addictive Audio v3. Building a t-line for the four tens is not an option for me because the box would not fit in my Jeep Cherokee.
Thank you for any and all input on this. I will most likely end up building both, but prefer to understand the science behind these things. From what I understand about quarter wave theory, transmission lines drop the notes by an octave. But how does an octave relate to Hz?
In all sincerity,
Evan
Old 05-22-2012, 08:37 AM
its_ray_ray's Avatar
OCD Member
1/11 sssss5696
Feedback Score: 23 reviews
I'm assuming you already have the subs?
Sent from your mom's phone.
Old 05-22-2012, 10:11 AM
0/11 ssssssss5
Yes, I already have both sets of subs.
Old 05-22-2012, 10:37 AM
Mr.G6's Avatar
0/11 sssss4614
lolll
2000 Gmc Sonoma ext cab
Old 05-22-2012, 10:47 AM
mega fatty
0/11 sssss6008
an octave is a doubleing or halving of a frequency.
so if its tuned to 40 hz one octave up is 80hz one lower is 20hz
i would do the 4 10's ported, it should have more output if done properly
07 mazdaspeed3
rd d9 @ .5ohm
The Following User Says Thank You to tymoto21 For This Useful Post:
ejbot (05-22-2012)
Old 05-22-2012, 10:59 AM
loud-n-low's Avatar
0/11 ssssss695
im going to say that 4 10's tuned to 25hz will not dissapoint.
Old 05-22-2012, 12:55 PM
0/11 ssssssss5
I am going for more sq than spl.
Should have probably mentioned that.
Yea, the whole octave is half the Hz thing makes sense.
But does a transmission line really put out an octave lower?
If so, I think it would serve my purposes better.
I make music with rather low bass
Old 05-22-2012, 01:26 PM
0/11 ssssss579
Build both and see what you like more.
Old 05-22-2012, 07:15 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
the idqs will easily have it. Newbs are going to say the t-line because it sounds cool but the ported 10s would easily do better IMO.
NEED HELP! T-Line Enclosure! Raptor660 General Car Audio Discussion & Questions 5 05-21-2011 01:26 PM
t line vs ported joejohanson.. General Car Audio Discussion & Questions 8 05-21-2011 04:35 AM
Ported enclosure djarmy2004 Enclosure Discussion & Design Construction Help 2 03-04-2011 10:05 AM
Ported diamond enclosure? mikeyg402 Enclosure Discussion & Design Construction Help 0 02-17-2011 02:40 PM
2.2cube @ 34hz 12 Enclosure surreal Speaker Accessories & Parts 2 10-01-2010 10:27 AM
