Building center consol enclosure, help! - Car Audio Classifieds!
Old 05-22-2012, 05:41 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default Building center consol enclosure, help!
Okay so as most of you truck owners know, its hard to get decently loud without losing seating! I have an idea to build an enclosure / center console, like others have done in the past. I'm just having trouble figuring out how to do it. My idea is to have the console lead from the dash, all they way to the front of the back seat, touching actually, so my middle rear seat will be useless. Should i make the sub down firing, how should i port it? Which way should the port be facing?
My max Dimensions:
15" - Wide
14 3/4" - Tall
43" - long
According to the Torres calculator i have ~4.30^3 before any displacement to work with. Now as far as power, i dont want to do any electrical upgrades, MAYBE a bigger battery under the hood and the big 3. I really dont want to run over 1500watts, so that being said what kind of options do i have for drivers? I would really like them upfiring, i wont have little kids in my truck so i dont have to worry about them being exposed and possibly getting damaged. I was thinking 1 beast 12, or maybe 2 sa-10's (or something along the lines) maybe some 8's? im sure you guys will have tons of idea's as far as drivers, and number of drivers to use.
This is just a quick design i threw together, 1-12" sub up, port back (firing under the back seat) tell me what you think.
And then ont eh front half of the box will do a little bit of fiber glassing, for my volt meter, bass, knob and cup holders.
Old 05-22-2012, 05:44 PM
Matt3824's Avatar
0/11 sssss3754
3 Sa8 v1s
Old 05-22-2012, 05:47 PM
Calebjcline's Avatar
Active Member
0/11 ssssss814
I'm running 2 Skar vvx10s in a center console box in my gmc sierra. They are in a 3 cu ft box tuned 35 hrtz. I was really impressed with the subs. They r running on a saz1500 at 1 ohm. I have big 3 and a 200 amp alt. Good enough for a 143.0. My build log is on here if I can figure out how to link the thread
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
Ryan1126's Avatar
0/11 sssss9178
hmm...well that enclosure right there ^ is [email protected], 40.5sqin of port.... thats before sub displacement though, obviously since i dont know what im gonna use in it yet.
Old 05-22-2012, 05:48 PM
Ryan1126's Avatar
0/11 sssss9178
yes i would like to see!
Old 05-22-2012, 05:52 PM
Ryan1126's Avatar
0/11 sssss9178
i just searched it and found it, that's exactly what im looking to do, is your port facing forward or backwards?
Old 05-22-2012, 05:57 PM
Active Member
0/11 ssssss814
Old 05-22-2012, 09:18 PM
Ryan1126's Avatar
0/11 sssss9178
after continuing further, i ran into a problem, to design the box this way, the port is going to butt up against the seat.....so now what? port to the side? if so which side? should i do an aero port? or slot?
Old 05-22-2012, 11:01 PM
Active Member
0/11 ssssss814
Port is firing off back of cab.
Old 05-22-2012, 11:03 PM
Active Member
0/11 ssssss814
here is the new box. Gonna try firing towards dash as well as back of cab. 3^3 tuned 34
Building a JL Audio sub enclosure Butterworth Enclosure Discussion & Design Construction Help 0 03-28-2012 11:32 PM
Building an enclosure without T/S boom_squid_1 Enclosure Discussion & Design Construction Help 5 09-21-2011 12:02 AM
Enclosure building question? Silas General Car Audio Discussion & Questions 23 04-22-2011 10:03 AM
Box for a single DD 1508, center console enclosure cwharding Enclosure Discussion & Design Construction Help 1 07-24-2010 11:53 AM
enclosure building software? aturcotte127317 Enclosure Discussion & Design Construction Help 50 08-02-2009 05:56 PM
