sundown sa box help - Car Audio Classifieds!
Old 05-23-2012, 12:13 PM
Ego Crusher
0/11 sssss1834
Default sundown sa box help
Ok I have 46 wide 31 deep and 18 tall to work with in the trailblazer, and I'm toying with the idea of either 3 sa15's or 4 sa12's. Cone area has me leaning towards the 3 15's but I dont know if I have the required amount of room for the 15's. I will be using a pair of DD m1b amps strapped for either setup.
Do I have enough room for the 3 sa15's?
06 trailblazer ss (Ego crusher)
Texas speed forged 408,custom cam, stalled
hp numbers coming soon
focal 4.160,fosgate coax in rear doors
popcorn sounds 6k ,2 sundown sa15, in a 6th
Old 05-23-2012, 12:32 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
With box your max dimensions assuming subs up port back double baffle on top you could get around 9 cubes @ 36 slot ported. Maybe a little more if you play around with it.
If you use 3 6" aeros you will have more than enough volume to tune it around 30-32hz. Depends on what you are going for.
Im sure others will chime in.
edit: this was for the 3 15s you can fit either one in your space if you work with it.
Box Design for 2 Sundown SA-8 v.2 bigdogjk (Sundown Audio) 15 09-25-2012 10:25 AM
Sundown z3 12 box help slouich Enclosure Discussion & Design Construction Help 1 05-13-2012 09:27 PM
what box for sundown sa 12"s scfaust (Sundown Audio) 14 03-30-2012 09:35 AM
Sundown Zv.3 12 box Isaac (Sundown Audio) 9 02-07-2012 09:20 PM
box for 2 sundown z 18 v.2 djscrubb (Sundown Audio) 4 04-19-2011 07:00 PM
