thoughts? ideas? comments? - Car Audio Classifieds!
Old 05-25-2012, 01:51 AM
perfect_prefect's Avatar
0/11 sssss1265
Default thoughts? ideas? comments?
i'm going to build a pine test box to see if this works or not but i want to build my series tuned 6th order with the rear chamber as an abc box. im going to build a slide in test box for a single 15 in my buddies truck but what are your thoughts.
single 15" 3 cubes 6" round ports 24" long, 1.5 cube side chamber, 1 port to front chamber 1 port between the rear chambers and 1 port out of side chamber. front chamber 8 cubes 150 in^2 @ 80hz.....................
test sub will either be a lvl4 with sundown z3 parts or a t3 t2000 with sundown parts
what do you think will happen? is there anything that could even model this?
Enough to do a 3 minute average on music of 150db
Old 05-25-2012, 02:06 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
tuned in
Current Build:
#60sHereIcome
Old 05-25-2012, 02:08 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Having some trouble visualizing it Gar. Would it look like this? (Not to scale obviously)
Old 05-25-2012, 02:24 AM
0/11 sssss1265
the port in the bottom left corner would not be there it would be right beside the sub firing parallel to the sub
Old 05-25-2012, 02:45 AM
666WMD's Avatar
0/11 sssss1307
Oh right, I read that as "One port out of the side of the side chamber". Idjit.
So what's the purpose of the side chamber? In simple Idjit speak if you can...
Old 05-25-2012, 02:48 AM
0/11 sssss1265
it's an aperiodic bi chamber enclosure, it is to increase bandwidth. it just happens to have a front chamber in front of it in this case
Old 05-25-2012, 02:50 AM
666WMD's Avatar
0/11 sssss1307
Oh I see. What's the lower cut off? 15hz knowing you...
Old 05-25-2012, 03:12 AM
0/11 sssss1265
nope low end tuning is 30hz....... should do well down low though
Old 05-25-2012, 03:32 AM
666WMD's Avatar
0/11 sssss1307
Well, if you think it'll work, I have faith.
Old 05-25-2012, 03:36 AM
ridintwo6s's Avatar
0/11 sssss1791
would this not be an 8th order?
[email protected] the comments on this video badmofo529 Car Audio Videos 1 05-08-2012 12:42 AM
Xmas ideas. 12" driver 400 dollarish budget got a few ideas need input tc sounds? fi? Brianyakno General Car Audio Discussion & Questions 5 11-22-2010 06:57 PM
JBL BPX1100.1 - buyin one today. Thoughts, comments, suggestions?? nefariouscaine General Car Audio Discussion & Questions 12 04-09-2010 06:06 PM
Racist comments Audioque General Car Audio Discussion & Questions 60 01-11-2010 11:55 AM
eBay Feedback Comments 92K1500 Off Topic Chat 5 03-30-2009 01:27 AM
