How about this box - Car Audio Classifieds!
Old 05-26-2012, 01:42 PM
reeftopia's Avatar
i always need more power!
0/11 ssssss517
Default How about this box
So I have a PSI recone on a DC XL 12". What do you think of this box for it?
I'll be powering it with an IA 20.1 @1 ohm.
Old 05-26-2012, 02:07 PM
Mr.G6's Avatar
0/11 sssss4614
looks good to me right amount of port area decent tuning
1.78 for a big boy 12 like that? maybe dc subs like smaller boxes..
but i try to keep my 12s in 2 cube or so
2000 Gmc Sonoma ext cab
Old 05-26-2012, 02:18 PM
reeftopia's Avatar
0/11 ssssss517
Dave at psi told me shoot for 1.75cf id like to tune lower but i done want the ports to be too long. but from what I have read DC subs do like smaller boxes. Thanks.
Old 05-26-2012, 02:33 PM
Decaf's Avatar
0/11 sssss3460
Feedback Score: 24 reviews
where u getting 1" thick wood?
Old 05-26-2012, 02:55 PM
reeftopia's Avatar
0/11 ssssss517
Wood workers source here in phoenix. It was only $44! My buddy has a discount card
Old 05-26-2012, 03:11 PM
0/11 sssssss45
Box looks good, port area is good, and yes DC likes smaller boxes. Also, next time, press "Print Screen" button above your "delete" key on your keyboard. Open Paint, and paste. Then save, and you got a picture of whatever is on your desktop.
Old 05-31-2012, 11:15 AM
reeftopia's Avatar
0/11 ssssss517
Thanks for the advice guys! I'll be cutting some wood for the box on Saturday. An I'm ordering some ports today. I hope to be done with this build soon.
Old 05-31-2012, 11:30 AM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
Aero Port Tuning Length Calc
According to that calc which is more accurate with aero port length tuning than Torres with 1.78 cubes and 2 4" aeros 31" long is 34hz tuning. Those ports are going to be very long.
Are you going to be firing the ports to the side or are you putting 90 degree elbows in them? Why is the box so shallow and wide?
Will the sub even fit in that box without the magnet hitting the back of the box? With the top depth being 5.25" and bottom depth being 10.5" the depth at the very center of the box will be about 7.75" minus wood thickness so even smaller than that and with the width of the motor I am not sure it will fit in there.
Just want to make sure its going to work for you before you build it and find out it doesnt. That would suck.
Also I would probably personally go for 2 cubes net if you can fit it tho it isnt much larger than 1.8 cubes should do pretty good either way.
And I see you are using 1" thick wood but baffle thickness is .75"? Are you doing 1" on all sides except the front baffle I am confused a little bit.
Which face of the box is the sub going on and which face for the ports?
Old 05-31-2012, 11:35 AM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
yeah your going to want to shoot for a little bigger box so your aeros arn't so long. just bump it up .25-.35. if your looking for lows, a slightly bigger box will help u achieve that.
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 05-31-2012, 11:42 AM
reeftopia's Avatar
0/11 ssssss517
Originally Posted by 98GCLimited View Post
Products Menu
Is shallow because it's for my standard cab f150. Ports will fire out the side. The sub will be as close to the bottom of the box as I can get it on the front side behind the driver seat. the mounting depth is just over 7" for this sub it should fit. Oh I forgot to change the front baffle from .75" to 1". I may try to make the box a little larger I need to do some more measuring I'm trying to keep some leg room. Lol hope this solves some of the confusion man. And thanks.
I was hoping to tune pretty low but I didn't want the ports to be ridiculously long. will the port length being so long cause any issues?
Dave the Box Guy Sub box for 2 15's 7'^3 @ 42hz for SUV 80$ OBO New England area hispls Wiring, Electrical & Other Installation Equipment 8 05-21-2011 02:43 AM
Michigan Box builders!! WTB box for two 15's kowboy Wanting to Buy (WTB) 14 02-14-2011 07:49 AM
Box design request for da box king ( 2-12" R's) da box king Box Requests 3 08-16-2010 04:23 PM
18" trunk box dual corner loaded square port box Jacobbz206 Enclosure Discussion & Design Construction Help 0 06-20-2010 06:53 AM
