Wide respones out of a DC lvl3 15" - Car Audio Classifieds!
Old 05-29-2012, 04:28 PM
0/11 ssssss639
Default Wide respones out of a DC lvl3 15"
What sort of box would you guys recommend? It's still more a thought than anything, but my 3 cube ported box is missing out on a lot of bandwidth.
Old 05-29-2012, 04:43 PM
Awaiting Confirmation
0/11 ssssss923
What is it tuned to and what do you listen too??
CAR: 1996 Cherokee sport
WIRE: 4 runs of 2/0
SUB: 3 NSV1 18's
AMP: 3 SAZ-3K's
BOX: 4th order wall
Old 05-29-2012, 04:59 PM
0/11 ssssss639
tuned to ~34 hz. I listen to a lot of stuff. Dubstep, rock, r&b, classic rock, some rap.
Old 05-29-2012, 05:26 PM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
how much port?
Current Build:
#60sHereIcome
Old 05-29-2012, 05:45 PM
0/11 ssssss639
Its a 6" aero. I think roughly 9.2 sq in per cube. I don't remember.
Old 05-30-2012, 02:05 AM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
whats the length of the port?
Old 05-30-2012, 04:45 PM
0/11 ssssss639
it is a 24x24x14.25 box. top mounted sub/double baffle. side firing port. Pull length psp port. I don't remember how long that was.
Old 06-01-2012, 12:43 PM
0/11 sssssss46
according to torres calc and displacement of woofer and port that would be 3.26cu tuned at 33hz the psp ports are what 17in in length? 8.67sq in port area what is your sub sonic and LPF set to? should be about 60-70hz ish for the LPF.. and subsonic usally around 7hz below tuning if im correct prob about 25hz? if im wrong someone can correct me but that box should be pretty nice for that sub maybe lacking a little in port area... maybe should have done like 3 :4in aeros that would give you about 12sq in port area but need more then 17in port length which i use PVC if thats needed longer then 17 and flare yourself about 22in give you a tuning of 35hz and 3cu for your sub after displacement.
Old 06-01-2012, 12:48 PM
0/11 sssssss98
12-15 in^2 of port :^)
Bought from: 06Titan, Bread0710, cdorton16
Traded with: tattoonick87
Old 06-01-2012, 12:54 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
I'm going through the same thing with my box...3 cubes with a single 6" aero tuned to 33 hz like above. It gets nasty around vehicle tuning but the low end response sucks...even at tuning. I've come to the idea that I'm using that box with an 8" aero now for my SPL box and building a 4th order with 2 12's for my daily setup...
You're not alone with the loss of bandwidth OP lol
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
DC Audio Lvl3 Motor and 10"/12" Basket 03tbls Speaker Accessories & Parts 14 09-05-2011 02:24 AM
SDC2.5 15" (improper box size I think) vs. DC Lvl3 12" Mousemonster1232 General Car Audio Discussion & Questions 13 08-18-2011 12:59 AM
DC Lvl3 motor and 12" basket 03tbls Wanting to Buy (WTB) 9 07-30-2011 09:44 PM
(SOLD) dc lvl3 12" dual vc psychoacoustics 12" Subwoofers 19 05-17-2010 10:35 PM
[SOLD](2) DC audio lvl3 12" psychoacoustics 12" Subwoofers 26 12-07-2009 03:04 PM
