design help sundown nightshades 15s - Car Audio Classifieds!
Old 05-31-2012, 11:15 PM
Brand New Members
0/11 ssssssss1
Default design help sundown nightshades 15s
hi there im stumped in how to design a box for my project here is what i have any help be great
1997 bagged isuzu extended cab (same as s10)
equipment
2 sundown 15 inch nightshades
2 sundown audio 3500d amps
sundown audio 100.4
memphis comps for now
i may only use 1 of the 3500s but wouldnt mind using both
id love to keep box below window height
goal is to be built in 2 weeks would love to be up in numbers as loudest in area is 151 they do soundoffs every other weekend here in duluth
can anyone help?
Old 05-31-2012, 11:20 PM
Eric B's Avatar
LowBlowBro
0/11 sssss2140
Get ahold of Anton Miller on here.
Old 05-31-2012, 11:30 PM
KEVGNAR's Avatar
0/11 ssssss928
Duluth mn? Dude named josh has 4 lvl4 18s in a 4th order and hes doin 55s with a hairtrick port, good luck man lmao
Old 05-31-2012, 11:36 PM
badmofo529's Avatar
0/11 sssss3329
subs forward port up to driver's side, about 5.5-6.5 cubes net (depending on power), about 90 in^2 of port tuned to 32. should wang, and have zero issues with being under the window line.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 05-31-2012, 11:46 PM
KEVGNAR's Avatar
0/11 ssssss928
But seriously you should have no problem pressurizing the cab with that setup,
2 sundown nightshades willie3719 18" Subwoofers 46 03-22-2011 10:27 PM
sundown nightshades willie3719 Car Audio Trader (WTT) 6 02-06-2011 09:45 AM
2 18" Nightshades design...PLEASE? Scapelli21 Enclosure Discussion & Design Construction Help 16 07-23-2010 02:34 AM
Redoing the Sundown audio Nightshades. splvictim20 Miscellaneous Build Logs 76 02-21-2010 05:41 PM
jbizzle's 2 18" Sundown Nightshades jbizzle Build Logs 29 02-22-2009 02:11 PM
