box help? - Car Audio Classifieds!
Old 06-03-2012, 04:33 AM
0/11 ssssss850
Default box help?
Im looking into a new build and want to do either 6 12s or 4 15s, to start off which would be better and then do i have enough cubes to make it work.
The 12s would fit ok my measurements are 50" wide 26" deep and up to 28" tall...not sure i have the room for 15s..
Just to note theyll be skar vvxs on a skar 4500 any help would b great, its a 94 bronco behind the back seat!
2 DC XL 15's, Sd5k
7.56 cubes after displacement
270 mechman alt, 1 deka up front, 1 c and d
Old 06-03-2012, 05:45 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
The 4 15's have far more cone area at -/+3200cm^2 as opposed to the 6 12's -/+2880cm^2.
4 15's will need around 12cuft net and 6 12's will need 9-12cuft net.
I'd do 4 15's, 50w x 28h x 24d, 1.5" material thickness, 3 8" round ports 18" long and 4" outside the box. That gives you 12.5cuft net, 150sqin port area, 12sqin/cuft, tuned to 34hz.
Alternately you could do 50 x 28 x 26, Slot port 10 x 16 x 30 and have 11.4cuft net, 160sqin port area, 14sqin/cuft and tuned to 29hz.
Old 06-03-2012, 10:49 AM
0/11 ssssss850
Ok man that sounds great! Thanks!!!
2 DC XL 15's, Sd5k
Dave the Box Guy Sub box for 2 15's 7'^3 @ 42hz for SUV 80$ OBO New England area hispls Wiring, Electrical & Other Installation Equipment 8 05-21-2011 01:43 AM
wts bassworkx box for two 12s portered box Zooook Speaker Accessories & Parts 0 02-03-2010 03:16 AM
