4th order designs - Car Audio Classifieds!
Old 06-03-2012, 06:20 PM
0/11 ssssss395
Default 4th order designs
so im thinking of walling my focus agian and was thinking of doing a 4th order with 4 type r 12s
sealded 6.1 cubes and ported 16.5
thats 2.7:1
tuned to 40 hz
sound ok they will be on a ab 200.1 at .5
or i do have a a ported box that i could seal the ports off its about 10 cubes
and just do 10 cubes for ported so it would be a 1:1 would that work out
ford focus (the black fucus)
build in progress
Old 06-03-2012, 07:29 PM
Hugh G. Rection's Avatar
0/11 sssssss88
ive worked on a few focus' and they have a good amount of room in them.
in a 4th, i would try 1.8 per sub sealed in a 1:3. should be able to fit it. i know a guy with this setup and it is ungodly. by far the single most impressive bandpass ive ever seen.
Old 06-03-2012, 08:31 PM
0/11 ssssss395
ok will do is 40 hz tuning to ,low or will it murder lows
build in progress
Old 06-03-2012, 08:36 PM
0/11 sssssss88
im tuned at 44hz and it is insane down to 25hz.......
Old 06-03-2012, 08:48 PM
0/11 ssssss395
ok just designed it 18 cubes ported 7.9 sealded tuned to 40 sound good
build in progress
Old 06-03-2012, 08:59 PM
0/11 sssssss88
so thats about a 1:2.27 ratio
it should work fairly well.
Old 06-04-2012, 12:04 AM
You don't need anywhere near that big of a sealed section. I would do 6 ft^3 total sealed. Make the ported chamber as big as you can. Tune to 45ish hz and you're golden.
Old 06-04-2012, 05:54 AM
0/11 sssssss88
i love when we get technical....
Old 06-04-2012, 06:27 AM
ridintwo6s's Avatar
0/11 sssss1791
1.5 sealed per sub?
huge for 12s
Old 06-04-2012, 07:20 AM
Micksh's Avatar
0/11 sssss2596
^^^ This...On the right track here. The "make the ported chamber as big as you can" may sound funny, but it's definitely true. Try to get as big a ratio as you can, within reason. 6 sealed, 18 ported would be good, or go a little smaller on the sealed side, like 5 sealed, 15 ported, and like he said, start around 45-46hz tuning. If you read the huge thread on 4ths with over 600 posts, there is a lot of good info in there...
My Youtube page
Astro build log link
4th order 6th order. btsteinb General Car Audio Discussion & Questions 1 11-13-2011 08:18 PM
4th Order vs. 6th Order? younggunzbass01 Enclosure Discussion & Design Construction Help 18 05-24-2011 04:34 PM
