Quasi 6th Order Bandpass port orientation... - Car Audio Classifieds!
Old 06-06-2012, 11:29 AM
0/11 ssssss111
Default Quasi 6th Order Bandpass port orientation...
Does it make a difference if the rear port is in the same axis as the front port, compared to the two ports being 90 deg out? Not much information out there regarding quasi (series) tuned bandpass enclosures...
Old 06-06-2012, 11:34 AM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
you mean like this ?
i havent finished this box yet, but it was designed by a reputable designer
so i have no doubts about it doing what i want it to do
Old 06-07-2012, 12:40 AM
0/11 sssss1230
No it is not a necessity. Post your design and we can help more.
Team Excessive
Old 06-07-2012, 10:16 AM
0/11 ssssss111
Here's the 4th order I'm considering converting to a series tuned 6th order. Do you think a straight port (in red) in the same axis as the front port (bottom right of pic) would be ok, or should I angle the new port (in blue) instead?
Old 06-07-2012, 10:18 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I don't like that.
Old 06-07-2012, 02:10 PM
0/11 ssssss111
Originally Posted by jt_buck View Post
I don't like that.
What, exactly, do you not like? The straight port, the 90deg port, or the whole 4th to 6th conversion idea, or?
Old 06-07-2012, 02:16 PM
mcmuffin's Avatar
0/11 sssss3380
to many words for me. all i know it loud.
*** NEW BUILD COMING SOON ***
its a secret for now
Old 06-07-2012, 02:40 PM
Ronmeister's Avatar
0/11 ssssss791
What's the total internal volume of the ported section? Gah, two ports at 180 from each other like that... I think it'll be a big flop to be honest. Cancellation too... Plus, because of woofer location I bet one port will pressurize and be more effective than the other. Then again, with a 6th order enclosures I suppose one port MUST pressurize of be more effective, not in q bad sense as the entire enclosure is built around the parameters at hand. Err, also, if you sealed the cutout and moved woofer location it'll still have the same problem I'd assume. I haven't the slightest as to what the beat location would be for the driver.
I can't wait for a guru to chime in, I'm interested in this concept now.
If it checks out on paper, remember that's the dynamics of this whole hobby crunch up paper and drain threes all day long with it in the ol' wastebasket.
Old 06-07-2012, 05:59 PM
HACKMUNCH's Avatar
0/11 sssss3892
what frequency do you plan on tuning internal port to?
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 06-07-2012, 10:18 PM
0/11 ssssss111
I'm starting off at 40Hz for the rear, tuning is easily changed. I should have it reassembled tomorrow and will post an impedance sweep. I'm hoping this will compensate some for the high sealed resonance I was experiencing in the 4th. Am I way off base here?
Tags
6th, bandpass, quasi
6th order bandpass for Justin (bubba906) [Completed] Bubba906 General Car Audio Discussion & Questions 50 11-22-2012 08:48 PM
What do you think about my 6th Order Bandpass Box Jdubs04ss General Car Audio Discussion & Questions 9 05-11-2011 12:59 PM
6th Order Bandpass Information jagblazer01 Enclosure Discussion & Design Construction Help 23 04-18-2011 02:55 PM
Four Selenium 6's in a 6th Order Bandpass For Fun Audio4life General Car Audio Discussion & Questions 17 03-17-2010 01:05 AM
Ported vs 4th vs 6th order bandpass sdelthon General Car Audio Discussion & Questions 20 10-19-2009 03:05 PM
