Two 18's in a S10 - Car Audio Classifieds!
Old 06-10-2012, 10:41 PM
SWIFT's Avatar
0/11 ssssss656
Default Two 18's in a S10
Well, I am fixing to start a build for a guy that bought my 18in Q's. He has a s10 extended cab truck. Not sure of year, maybe early 2000's. After measuring I think I will do a sub forward port up across back design. I came up with 10.6cu after all displacement and bracing, with 142in of port (13.5in per cube)
Im working with 49W x 31H x 20D out side dimensions, I will flush mount in a double baffle and the rest will just have to be braced well.
Port will be 3 x 47.5 alone the top back of box tuned at 30hz.
I think in this tiny truck it should get down pretty good even though its on the small side. Any opinions?
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
Old 06-10-2012, 10:47 PM
ridintwo6s's Avatar
0/11 sssss1791
sub up port side works well, as well as sub up port up but subs forwards put up is also well
Old 06-10-2012, 10:51 PM
badmofo529's Avatar
0/11 sssss3329
just letting you know, you will be raping the dash with 20d. im at 16 and im all up in it.
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 06-10-2012, 11:01 PM
LivinLoud's Avatar
0/11 ssssss524
I have 18.5 I believe and I sit nicely. (6'1) Passenger side isn't as good. Subs forward port up if you wanna compete alot. Daily I would do it to the side. I have mine Subs forward port up and tunned to 35 it peaks 57. Lmfao
Team Tantric Sounds
2 Tantric Sounds HD 15's
2 Digital Designs M2a's @.5
155.5 outlaw
REF:Loudwhat?,Retroaudioinc, statonburrell,Ho-Audio
well hello fartbox zen master
lol
Old 06-10-2012, 11:05 PM
SWIFT's Avatar
0/11 ssssss656
Man I know right? I made the measurement with the guy sitting in the drivers seat moved up as far as he felt comfortable. He is a little guy but still. It basically comes to the center console. This puts the box up mid window level. I just hope this is enough airspace. Cant get more unless I go wider but I would like to mount amps on each side so they arent stuffed under box / floor.
Old 06-10-2012, 11:06 PM
0/11 ssssssss9
Me likey haha yeah his ball's are gonna be on the steering wheel lol at least mine are and my box is 5.5 cubes
Old 06-10-2012, 11:12 PM
badmofo529's Avatar
0/11 sssss3329
too bad he doesn't want to wall
'97 chevy s10
-kenwood x994
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
SWIFT's Avatar
0/11 ssssss656
Damn thats high..... That doesnt sound attractive. I can build a nice enclosure but cant control vehicle affects. Hopefully this will sound good in the 30's
Old 06-10-2012, 11:28 PM
0/11 ssssss103
subs forward prot well be the loudest for sure ...going that high u might as well build a wall n give him some leg room
Old 06-10-2012, 11:38 PM
mylows10's Avatar
0/11 sssss2210
Feedback Score: 17 reviews
subs up port up.i had the loudest s10 in the country ,with no wall or cut thru under the window line
2 !8's in a s10 LivinLoud General Car Audio Discussion & Questions 7 12-05-2011 08:23 AM
DCs in my s10 premierdime (DC) 36 11-30-2010 01:43 PM
[SOLD]14.5 cf3 enclosure for 3 18's could use it for 2 18's also in Michigan 46panel Wiring, Electrical & Other Installation Equipment 10 09-30-2010 04:10 PM
93 S10 Blazer Help. Kicker Guy General Automotive Chat 4 03-09-2010 11:48 PM
94 s10 2.2 akmarcos12gauge General Car Audio Discussion & Questions 1 02-27-2010 08:38 PM
