6th order guys I got a question - Car Audio Classifieds!
Old 06-12-2012, 08:08 PM
jj53913's Avatar
0/11 ssssss720
Default 6th order guys I got a question
Not sure if this is something that you want posted publicly or not but he's my question
is there a way to determine a optimal distance between the subs and the loading wall?
I am pleased with how my 6th order plays, just contemplating options to increase the spl for comps without sacrificing what it already does.
Right now I run 2 m2xl 18s. my scores ate in the [email protected] And that's not a bad number but in ss1-2 wall or advance 2 wall (I think those are my classes) they aren't competitive enough.
Sent from my PC36100 using Tapatalk 2
TEAM DC
Team SD
ebayID
ca.com References: Kenneth10483(BF), goodie (Traded), SPY (Sold to), kovemaster559 (BF), ExpoSport (BF) SPLluminator (traded&sold), Branham1127 (bf), NoPh33rRaCiNg (bf), Zookporter17 (bf)
Old 06-15-2012, 12:17 PM
0/11 sssssss21
You need to beg, borrow, or steal access to a db meter. Distance from the loading wall is only ONE of many factors involved in boundary loaded subwoofers. No one will be able to tell you optimal placement in your vehicle unless they have tested that particular vehicle.
Keep in mind tht you dont have to test it at full tilt for measurement. For optimal results, repeatibility in the tests should be your goal. For that reason, a 1000 dollar TL is not required; any db meter will be better than what you have. They even have db meter apps, but i cant speak for their precision or accuracy.
6th order wall ratio question 46panel Enclosure Discussion & Design Construction Help 52 02-23-2012 08:28 PM
4th or 6th Order? Question/Help/Advice/Tips/etc Please David97 Enclosure Discussion & Design Construction Help 7 11-04-2011 11:58 AM
