Re audio box - Car Audio Classifieds!
Old 06-14-2012, 03:16 PM
0/11 sssssss22
Default Re audio box
I have 2 re audio sex12's dual 4 ohm and a re audio xt4000 at 1 ohm pushin around 500 to each sub. My box limit is 37" wide 14" tall 18.5 to 19"deep. I want to use a aero port.What size port should i use? I want to tune to 33hz. This box should be around 4 cubic ft,some calculators have said they need about 3.4 cubic feet per sub(going by speakers vas,fs,qts. .. Im wanting to know if a 4 cubic for both will work. Thanks for any help
Old 06-14-2012, 04:38 PM
0/11 sssssss22
More info, these are goin in a 2007 lincoln mkz,subs and port facing cab sealed from trunk.
Old 06-14-2012, 04:45 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
For 4cubes net @ a 33Hz tuning, use x2 4" aero ports @ about 13.66" long each.
Products Menu
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
The Following User Says Thank You to jmelton86 For This Useful Post:
Cheesepuff372 (06-14-2012)
Old 06-14-2012, 06:02 PM
0/11 sssssss22
Ok, so 2 4" tubes would be better than 1 6" port? Just curious, never had a aero port and just want to make sure its the best it can be and thnx for your help jmelton86!
Old 06-14-2012, 06:12 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
I believe 1 6" port would be too large for 2 "medium duty" 12's.
KeepItSimpleStupid
JL Audio Box BKNIGHTS Wiring, Electrical & Other Installation Equipment 0 06-10-2012 05:09 PM
2 new in box ma audio 800xl 8s howyadoin 8" Subwoofers 10 06-25-2011 10:07 AM
[SOLD] M-Audio Audio Buddy Preamp/ Direct Box goodstuff Head Units, Processors & EQs 43 02-18-2011 04:50 PM
re audio sx 15 box help JOSEPHKEMP Enclosure Discussion & Design Construction Help 1 05-06-2009 12:09 PM
JL audio W7 10" in a JL Audio H.O box, JL audio 500/1v2 amp, stinger cap s10 with 4 15's Car Audio Packages 8 03-22-2009 01:50 AM
