Rule of thumb on width of port. - Car Audio Classifieds!
Old 06-15-2012, 10:32 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Default Rule of thumb on width of port.
Whats the rule of thumb on width of a slot port for 2 12" subs running roughly 1000w each? Dropping the tuning without making the port width tiny is proving a challenge.
Old 06-15-2012, 10:33 PM
o 16K o's Avatar
0/11 ssssss166
try making the heighth smaller ??
8 12" PSi MT Subs - SounDigital 16KD Amp - Mechman 220a HO Alt- 6 XS Power D3100 Batteries - Copper Buss bars - 4/0 Cable
Old 06-15-2012, 10:46 PM
Ricksi30's Avatar
0/11 ssssss997
Originally Posted by davidrforbus View Post
Whats the rule of thumb on width of a slot port? Dropping the tuning without making the port width tiny is proving a challenge.
What are you asking exactly? There isn't a "rule of thumb" it all depends on the equipment.
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Team SSA
Old 06-15-2012, 10:47 PM
0/11 sssss6030
Your right should have been more clear. Edited.
Old 06-15-2012, 10:52 PM
0/11 ssssss249
Default rule of thumb
The only real "rule of thumb" is port area 12-16 sq in per cubic foot. Make the box bigger and the port longer and wider remember to calculate port volume into you equation. I usually work backwords and calculate my port volume then design my box and make the port fit.Edit: if your using 2 subs it is much easier to accomplish this with a common chamber the only drawback to this is if one of the subs takes a crap the other sub could be damaged as well.
Old 06-15-2012, 10:53 PM
Ricksi30's Avatar
0/11 ssssss997
The edit is better but knowing the actual equipment is necessary. If you have low excursion 12's you will need less port area, high excursion drivers would need more.
Team SSA
Old 06-15-2012, 10:55 PM
Ricksi30's Avatar
0/11 ssssss997
I really dislike this "rule of thumb"
Team SSA
The Following User Says Thank You to Ricksi30 For This Useful Post:
Audiointelligent (06-17-2012)
Old 06-15-2012, 10:57 PM
o 16K o's Avatar
0/11 ssssss166
whys that lol ??
Old 06-15-2012, 10:58 PM
0/11 sssss6030
Damn, They are high excursion drivers, OA-12's.
Old 06-15-2012, 10:59 PM
Ricksi30's Avatar
0/11 ssssss997
Originally Posted by o 16K o View Post
whys that lol ??
Because if you understand how a port works you would know that enclosure volume is not the deciding factor in what size your port should be.
Team SSA
is there like a rule of thumb for how many battys you need to keep voltage stable Craig28 General Car Audio Discussion & Questions 13 07-18-2010 03:53 AM
Check your thumb Violence* Off Topic Chat 9 07-06-2010 08:10 PM
wheel width for chevy cobalt? KickerCobalt General Automotive Chat 4 01-25-2010 01:35 PM
Total width of HDC310 bland General Car Audio Discussion & Questions 3 10-07-2009 11:02 AM
'Standard' sub enclosure width? altendky General Car Audio Discussion & Questions 0 09-11-2009 07:09 PM
