Box Building use 45s or no? - Car Audio Classifieds!
Old 06-16-2012, 10:01 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
Default Box Building use 45s or no?
So I see a lot of people do 45s and I have before but some people arent using 45s too.
Do you use 45s in your corners on slot port boxes and do you use a 45 in the L port bend?
I have so far on my slot port boxes and I would assume doing 45s in corners and especially in the bend of the L port to help airflow?
Is there really any reason that not using 45s would be better?
Old 06-16-2012, 10:03 PM
0/11 ssssss182
Using 45s and not using them completely changes how the box works
Both work either way, but if you want to use 45s, you need to design it that way or it will mess up the airflow and waves of the subs
Old 06-16-2012, 10:12 PM
0/11 sssss1921
This is what I have done in the past. Would this be correct or incorrect use of 45s?
Old 06-16-2012, 10:24 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Completely changes it? Care to expound on that? And how you design it that way so it doesn't mess up the airflow and waves?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 06-16-2012, 10:28 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
none of my boxes ever had bracing or 45's.all were made from birch and all were resined inside.
My game is legit,
Old 06-16-2012, 10:31 PM
0/11 ssssss182
Alright maybe i was being a little drastic,
It does not completely change it,
But let's use my box for example.
If i didnt use 45s,
It wouldn't have the correct back-wave profile from what I designed, thus won't do as I designed it to, losing output, and adding vent length, meaning that the Front Wave, from the woofers, and the backwave from the vent, won't be as I modeled it, and that was optimal.
Old 06-16-2012, 10:34 PM
DC98hoe's Avatar
Doing 156s below the seat
0/11 sssss1372
I disagree... if your spl competitor you will lose with.45s... id use just 1 on wall opposite of port
98 tahoe 4-team ascendant 18s ,2-Flatline 9.5s 18 v --singer 320 hairpins-4th order 160dbs
Old 06-16-2012, 10:35 PM
0/11 ssssss182
My box is designed for Daily usage, NOT Spl
0/11 ssssss182
2 12" Sundown SA's
Tuning: 33hz.
Compression Chamber: 3.2cuft
Resp: 26hz - 71hz
My Specs
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
If i didnt use 45s,
Have you tested it with and without the 45's to verify that? What "back wave profile" are you talking about? Is this something you modeled up? How much vent length would it add?
Also, how's that sub closer to the port doing? It has to be loading like crazy.
4x world champ
- Floyd E. Toole
Woodgrain box? 45s/Rounding? Help. Matt3824 Enclosure Discussion & Design Construction Help 1 11-20-2011 10:47 PM
box building JAYARE2007MAG General Car Audio Discussion & Questions 2 02-19-2011 07:18 PM
Building a Box for 13 w7 KRestevan Enclosure Discussion & Design Construction Help 6 03-23-2010 12:28 AM
Building first box. KcRidin09 Enclosure Discussion & Design Construction Help 6 03-19-2010 03:00 PM
New to box building.. Mojo Enclosure Discussion & Design Construction Help 37 03-19-2009 11:29 PM
