how to figure up center port - Car Audio Classifieds!
Old 06-17-2012, 09:22 PM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
Default how to figure up center port
I used winisd just to come up with basic stuff usually, but I always just build box and use 1 wall of the box for 1 port wall. Now I am trying to figure up how to calculate the length of a center port. I built box inside a scion xa for guy locally to get the most we could out of his car. Its 21.75 internal cubic feet, and was told to use 240 square inches of port area. So my port opening will be 40" H and 6" wide. My question is how long does it have to be to be tuned to 30hz? If I use winisd, and put port on driver side on the wall, it says make it 16.75". How do I figure up to do the center port? Thanks for any help or some links to help
2 FI bl 18's walled in 2012 scion xb
Old 06-18-2012, 02:33 AM
0/11 ssssss532
20.25" long Car Audio - PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES
Old 06-18-2012, 01:53 PM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
If the box is 21.75^ft gross volume, you will need to make the port 36" long to tune it at 30hz.
The port area will be 17.4 sq" per^ft
The net volume after port displacement is 13.8^ft which doesn't include the displacement of the subs since I'm not sure what you are using.
Let me know what subs you are using and the box dimensions and I will figure out the tuning with the sub displacement.
Old 06-19-2012, 01:50 AM
98Expo's Avatar
0/11 sssss1929
i got it all done
I can't figure out this port! Help please DylanH Enclosure Discussion & Design Construction Help 8 10-03-2011 01:14 AM
how to figure port area? Ryan1126 Enclosure Discussion & Design Construction Help 31 12-18-2010 06:12 PM
Need to figure round port area? madmat Tutorials & Quick References 0 06-30-2010 09:35 PM
Cant figure out port length.... Ryan1126 Enclosure Discussion & Design Construction Help 10 06-22-2010 05:48 PM
How to: Figure port area SPL Guru Tutorials & Quick References 3 08-04-2008 11:24 AM
