slot port help?!?! - Car Audio Classifieds!
Old 06-17-2012, 11:00 PM
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
Default slot port help?!?!
this is my box and i have it all done just need to finish baffles and size of port pieces....can sumone help me figure out the size of the two pieces that i need to make the slot port?
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 06-18-2012, 12:13 AM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
1 16" long x 14.5 tall and one 7.25" long x 14.5 tall
16+7.25 =23.25 Thats assuming your not putting a 45 in the corner of the box. Also need to know if its going to be part of the baffle or not.
Old 06-18-2012, 04:31 AM
0/11 sssss3682
Yes sub n port same side...thanks alot sum reason this wasn't making sense n the ole' noggin lol
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 06-18-2012, 04:32 AM
0/11 sssss3682
I need 27" port length
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 06-18-2012, 04:35 AM
0/11 sssss3682
So....14.5x14.5 first piece....then 14.5 x 12.5....... that should get me 27" of port length corect?! Thanks
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 06-18-2012, 04:38 AM
0/11 sssssss89
no read your stat sheet "physical port length" should be 23.25" the torres calc takes your dimensions into consideration
Old 06-18-2012, 04:45 AM
0/11 sssssss89
but if my calculations are correct i think this
16+7.25 =23.25
should be 15.25" x 14.5" and 7.25" x 14.5" to get a total of 23.25" right
Old 06-18-2012, 04:46 AM
0/11 sssss3682
Right on....thanks....so Davids dims are correct...thanks......I've been lazy last year or two I've been using aeros lol time to get into slots again lol thanks for the crash coarse ...refreshing
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 06-18-2012, 04:49 AM
0/11 sssss3682
but if my calculations are correct i think this should be 15.25" x 14.5" and 7.25" x 14.5" to get a total of 23.25" right
Yea ....that's y he asked if it was w baffle or not that 3/4 u took off was from if that part is flush w baffle right?......
98 Taurus
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 06-18-2012, 04:53 AM
0/11 sssssss89
yes it is so wasnt sure how your port was aligned
SPL box... Slot port? Port Tube? Kerf? CousinVin Enclosure Discussion & Design Construction Help 13 07-21-2011 02:41 PM
aero-port vs. slot port? thumper21 General Car Audio Discussion & Questions 23 03-22-2011 12:12 PM
~143^2 Aero Port vs 235^2 Slot Port for 21 net cube enclosure VOPA1 Enclosure Discussion & Design Construction Help 6 12-02-2010 05:03 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
