2 18's backseat no wall ? - Car Audio Classifieds!
Old 06-19-2012, 12:52 PM
4ozgloves's Avatar
0/11 ssssss309
Default 2 18's backseat no wall ?
Being from pa it's illegal to wall a car here. Has anyone done a backseat setup to keep the view out of the back window intact. I have a couple btl 18's and an opti 6k. I will NEVER compete , it's just gonna be a loud daily. I have at least 16 cubes to work with staying under the rear deck. I don't care about numbers I care much more about moving some major air and sounding good. Any help on sub and port placement would be great.
Old 06-19-2012, 12:54 PM
0/11 ssssss395
i would think port up subs up would work the best or sub up port back will loading wall behing box toward trunk
ford focus (the black fucus)
build in progress
The Following User Says Thank You to littleharv93 For This Useful Post:
cbrenly09 (06-19-2012)
Old 06-19-2012, 12:56 PM
tacomaguy1's Avatar
0/11 sssss4401
what vehicle
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 06-19-2012, 01:02 PM
4ozgloves's Avatar
0/11 ssssss309
Originally Posted by tacomaguy1 View Post
what vehicle
95 roadmaster
Old 06-19-2012, 05:20 PM
4ozgloves's Avatar
0/11 ssssss309
I ran a bl 18 off 1.5k in my old 2.5 rs sub up port up and it sounded great and got loud I'm just wondering if I went sub forward port up if I would see a gain.
Old 06-19-2012, 05:27 PM
0/11 ssssss386
in a different car I saw a guy do 3 15's forward (back seat box below window line) and huge port back into the trunk , sounded good and loud. ON the meter he was louder with the subs forward and port up though...I know you not competing but that info may help you decide. With your car, don't you have some kind of bracing behind the back seat anyway? Would be an issue if your going port back So I would do subs forward port up. Or subs up port up if there is enough width. That will probably be your deciding factor anyway. If you do subs forward and port up you will have more room for port.
2013 and 2011 Midwest SPL Extreme Trunk Champ
94 Honda Accord
Two DD 9915 SC front firing out of the trunk
2 DD M4a's
Old 06-19-2012, 05:33 PM
SWIFT's Avatar
0/11 ssssss656
If it would work I would do subs forward and port long across ways firing up through / or remove the rear deck. The port would load off the rear window. Subs would be firing forward directly behind fronts seats. You would have a large flat level surface on top of box, with the rear windows up I would think you would get lots of cabin gain. Amps and batteries in trunk.
2012 F250 Lariat, lifted on 22's and 35's
4 DSS Ethos 18's flat wall, 2 Ampere Audio 7500.1's
Mechman 370, 9 batteries, Rockford Punch Pro front
Team DSS / Team Ampere Audio
Old 06-19-2012, 05:59 PM
Matt3824's Avatar
0/11 sssss3754
16 cubes? Easy. I did. Subs forward port up. It was in a silverado though but it was less than 16 cubes gross
Old 06-19-2012, 06:20 PM
4ozgloves's Avatar
0/11 ssssss309
I do have a ton of reinforcement between the trunk and the seat , I would love to go the pioneer~Saturn route and port through the rear deck but I don't want to cut up my car. I have more than enough width to go port and subs up something like 55 inches with the door panels still on.
Old 06-19-2012, 06:45 PM
armykyle1's Avatar
GFY&FYC
0/11 sssss6187
Feedback Score: 23 reviews
My current rig. It seems to do fine. Not an optimal box.
I say go for it.
Team XS Power
Team Heavy Hertz
Build-
youtube-
The Following User Says Thank You to armykyle1 For This Useful Post:
4ozgloves (06-20-2012)
wall or no wall, scion xb, Obsidian audio 18's 98Expo Enclosure Discussion & Design Construction Help 20 06-07-2012 11:48 AM
4 18's wall btsteinb General Car Audio Discussion & Questions 2 11-08-2011 11:48 PM
should I wall or inverted subs up port back for 2 18's...?? NorthBeat General Car Audio Discussion & Questions 5 07-29-2011 11:07 PM
Stay ported or try 4th order bandpass wall for 4 18's?? 46panel General Car Audio Discussion & Questions 7 05-17-2011 03:19 PM
a wall for 2 18's in a 4dr audi a4!? snoopysnooper Enclosure Discussion & Design Construction Help 1 07-11-2009 12:41 PM
