need help with box and sub decision - Car Audio Classifieds!
Old 06-26-2012, 03:22 AM
0/11 ssssss463
Default need help with box and sub decision
Well I recently purchased a 2011 chevy silverado reg cab base model I've been wanting to put a system in it but don't know what size.box and subs to go with I have no experience in shallow mount subs I have a small area to work with and was hoping to run 2-3 12s I was hoping for tons of output with great sq any help or recommendations on brands and even building a box for me all help will be greatly appreciated thanks in advance
refs:
caco=bangin_explorer,ssackett,ridnclean,lyttleviet ,LebonezerScrodge,clbolt,aturcotte127317,deafdream z,seattle206,hornedfrog
carstereo.com=FIERYWINTER,VTOWNDJ,wprivateer,usadt 23,iliveforbass
ca.com=Louisiana_CRX,lyttleviet,seattle206,korn4li fe,yunvme666,psychoacoustics
smd.com=kiannian
Old 06-26-2012, 04:12 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Shallow mount subs and tons of output generally don't go together. And great SQ usually doesn't go with tons of output.
Have a look at Sundown's SD line. They're not Shallow mount per say, but they have a small mounting depth at 4.75". 2 12's in a ported box will probably get louder than 3 in a sealed. And you'll need less power to run them.
State a budget too, or you'll get insane suggestions leading up into the $12-1500 range for 3 subs.
Old 06-26-2012, 02:18 PM
0/11 ssssss463
Well budget would be 300-400 for the subs and box I'm just looking for good sound out of a reg cab and if someone could also build I box for this to pm me
refs:
smd.com=kiannian
Need help with decision. hegar817 General Car Audio Discussion & Questions 1 03-14-2012 10:12 PM
sub decision ? 89boxchevy General Car Audio Discussion & Questions 0 08-25-2011 12:30 AM
Help with decision Gabriel ruiz General Car Audio Discussion & Questions 0 11-17-2010 11:57 AM
Need help with a decision MHD2000 General Car Audio Discussion & Questions 0 05-27-2010 03:08 PM
Should I.... fix my amp.... or buy new amp. Decision decision Vaginatarian General Car Audio Discussion & Questions 3 02-11-2010 05:28 AM
