Home Audio box question - Car Audio Classifieds!
Old 06-27-2012, 04:42 PM
TEAM 6HZ UNDER
0/11 sssss2020
Default Home Audio box question
i just bought two 8 in subs and i am going to do a fourth order bandpass box and i was wondering what ratio to use and how big the sealed side should be. i know this isnt a home audio forum but all opinions are good.
here are the specs on the subs:
Power handling: 65 watts RMS/90 watts max VCdia: 1-1/2" Le: 1.07 mH Impedance: 8 ohms Re: 7.58 ohms Frequency range: 40-5,000 Hz Fs: 52 Hz SPL: 85 dB 1W/1m Vas: 0.76 cu. ft. Qms: 4.77 Qes: 1.45 Qts: 1.11 Xmax: 3 mm Dimensions: Overall diameter: 8", Cutout diameter: 7-5/16", Depth: 3-7/16".
1998 Grand Cherokee 5.9 - Sony HU, Stock Infinity Mids/Highs (for now), OA18 v2, AP mini 1500 (fight me)
We all on here were newbs at one point in our life thats what alot of ppl seem to forget its about the love of bass at the end of the day
Old 06-27-2012, 04:44 PM
Micksh's Avatar
0/11 sssss2596
Might want to do a quasi-6th....depending on the sub specs..possibly Hackmunch or someone who knows them well will post a reply....
My Youtube page
Astro build log link
Old 06-27-2012, 04:48 PM
TEAM 6HZ UNDER
0/11 sssss2020
i would but the website says the subs perform optimally in sealed designs...
Old 06-27-2012, 08:17 PM
TEAM 6HZ UNDER
0/11 sssss2020
Nobody has an opinion? I find that hard to believe...
Old 06-27-2012, 08:36 PM
HACKMUNCH's Avatar
0/11 sssss3892
Qts is super high, from ts parameters I would go 2cft shared, 3:1 minimium ported to about 50hz
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 06-27-2012, 11:01 PM
TEAM 6HZ UNDER
0/11 sssss2020
Why port so high?
Old 06-28-2012, 03:46 AM
Originally Posted by IowaBass View Post
Why port so high?
Because that's how 4th orders work. I second HACKs recommendation, although unless you really just want a large box you'll probably like those better in a simple sealed box corner loaded in your room.
Old 06-28-2012, 09:18 AM
TEAM 6HZ UNDER
0/11 sssss2020
I just assumed fouth orders are best for home audio since most home subs I see are fouth but I guess I could do a down firing sealed.
Old 06-28-2012, 11:52 AM
Are you thinking of a regular ported box? I've also heard of that referred to as being a 4th order enclosure, but we are talking about a bandpass design. If you are talking about a vented enclosure, I would advise against it with those specs. Stick with a moderate sized sealed enclosure.
Old 06-28-2012, 12:23 PM
TEAM 6HZ UNDER
0/11 sssss2020
i know the difference between bandpass and ported. most home subs ive seen were fourth or possibly sixth. either way you couldnt see the sub there was only a port ya catch ma drift?
Audio Enhancers KO 12 Box Question.. ndgamer General Car Audio Discussion & Questions 2 07-19-2012 10:06 PM
Home Audio Reciever Question 2000LaDe General Car Audio Discussion & Questions 19 09-23-2011 09:52 PM
Home audio question mitcht22 General Home Audio/Video 4 03-03-2011 01:55 AM
Home Audio guys, quick easy question! MisterGrubbs General Home Audio/Video 6 06-03-2010 07:50 PM
high end Home sub question HCCA12 General Car Audio Discussion & Questions 39 06-03-2010 03:08 PM
