Need a few ideas for Isuzu box - Car Audio Classifieds!
Old 06-29-2012, 08:19 PM
beatnbronco's Avatar
0/11 sssss2284
Default Need a few ideas for Isuzu box
My brother has a single cab Isuzu pickup. He's a hoss at 6'3" and 260 lbs and looks like donkey kong on mario kart in this little truck but we want to install a 12" diamond d3 sub, mounting depth of 7". He doesn't want to do away with the pass seat or cut the cab right now for a blow thru, but plans to do it later when he gets either a bed cover or snug top. He has a floor shifter, measurements from back of cab to floor shifter is 23", 8" between seats with arm rest removed. Can someone give me some ideas for a box for this sub? He has a big chevy truck also but it sucks a significant amount of gas with the 454ci and this isuzu is the better for gas, so he just wants a little bump in it for entertainment. thanks for the help, in the meantime i'll be on torres' calculator trying to figure it out...thanks again
Old 06-29-2012, 08:33 PM
Pioneer~Saturn's Avatar
Idk what Im talking about
0/11 sssss8346
If you could make a simple paint sketch with dimensions on it I could probably help you a few evenings from now
Louder. Lower.
Team Tupperware
Old 06-29-2012, 09:35 PM
Matt3824's Avatar
0/11 sssss3754
Start the sub box from the right edge of the driver seat all the way over to the passenger side. Make the back peice of the box continue all the way to the driver side for an amp and any other accessories to mount to. You can also get more room by removing any carpet an trim panels behind the seats.
Old 06-29-2012, 10:15 PM
0/11 sssss2284
i'll get something together..love your build btw
Box ideas xnewbx General Car Audio Discussion & Questions 10 06-26-2012 12:32 AM
Box ideas GoInGdEaF1990 General Car Audio Discussion & Questions 0 05-17-2012 01:34 AM
box ideas ja0879 (DC) 0 05-16-2011 02:24 PM
ideas for a box 28-32 hz only bobbygilly Enclosure Discussion & Design Construction Help 3 08-10-2010 11:37 PM
