Sub and port placement.. - Car Audio Classifieds!
Old 06-30-2012, 05:40 PM
0/11 sssss1741
Default Sub and port placement..
Ive always wondered.. Is it going to affect anytihng when you have a layout like this? My concern is that one sub is "loading" off the port, and the other is going off the back wall of the box.. Wont that make some sort of difference, or does it not really matter?
Old 07-01-2012, 02:35 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
Some will say yes and some will say no.
Old 07-01-2012, 02:51 PM
0/11 sssss2095
The op, may want to know what would you say.
Old 07-01-2012, 03:26 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
I have done what he is thinking with no I'll results. My current box is like that and works awesome.
My game is legit,
Old 07-01-2012, 03:28 PM
0/11 sssss1921
Should be fine.
Old 07-01-2012, 03:33 PM
0/11 ssssss577
should be totally fine, if your worried about un even loading do a center port
The Following User Says Thank You to harrisondesigns For This Useful Post:
armykyle1 (07-01-2012)
Old 07-01-2012, 03:35 PM
0/11 sssss1741
I dont think I can do a center port since the port is too long and has the bend in it..
Old 07-01-2012, 03:50 PM
0/11 ssssss577
just divide the length after the bend in 2 then use that length on each side of the port ex: if it was say 10" put a 5" piece on each side, just make sure to maintain the width of the port on each side.
Old 07-01-2012, 03:55 PM
0/11 sssss2095
I did not know you can do that, are you sure
Old 07-01-2012, 04:03 PM
0/11 ssssss577
yes i have done it a few times works great, just make sure everything is even, you dont want one chamber or one port smaller then the other
Sub and Port placement? jessdabest77 Enclosure Discussion & Design Construction Help 2 11-13-2011 10:07 PM
Need help with port placement. themgators511 Enclosure Discussion & Design Construction Help 6 06-23-2010 04:12 AM
port placement Xtremelegend General Car Audio Discussion & Questions 4 05-05-2010 08:16 PM
port placement mmwwjr Enclosure Discussion & Design Construction Help 7 04-24-2010 06:38 AM
sub/port placement? Ryan1126 General Car Audio Discussion & Questions 20 04-01-2010 05:45 PM
