4 hdc3 18s in a 6th order? - Car Audio Classifieds!
Old 07-05-2012, 08:36 PM
vince79vette's Avatar
0/11 sssss2011
Default 4 hdc3 18s in a 6th order?
I have a jeep Cherokee just like sundown Jared's. And I want to do a 6th order. What size requirements for the portes box and hz and what size for the front portes box and hz
Sent from Chuck Norris foot
Old 07-12-2012, 12:42 AM
ltr450racer690's Avatar
0/11 sssss3414
I don't think you will have the space for it. Maybe a 4th. But if I remember right. Jared only has around 40 cubes
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
Old 07-12-2012, 06:33 AM
0/11 sssss2011
The hdc3 hate sealed boxes so I can't do a 4th order. I am sending them about 2000 watts so 5 cubes each each gives me 20 and leaves me 20 to play with not including displacement
Old 07-12-2012, 07:06 AM
Dunder Mifflin
0/11 sssss1897
To give you a idea I have a 6th order blowtrough design that's about 40cubes total with the rear chamber 10cuft and 30cuft front chamber for 2 18" hdc3's!!! What amp you using ?
jordan i want my subs
Old 07-12-2012, 07:22 AM
0/11 ssssss125
You'd probably be better walling and sending them 10 to 12k
Old 07-13-2012, 07:28 AM
0/11 sssss2011
Just talked to Jared and he say he has about 52 cubes to play with and I am using 4 solid audio f15 at .5 at 15.9 volts
Old 07-13-2012, 08:01 AM
profundus-sanus's Avatar
Veteran Member
0/11 sssss3026
well, you're going to need as much room as you can get with that.
50 cubes net is a minimum for 4 18's in a 6th imo.
The Following User Says Thank You to profundus-sanus For This Useful Post:
perfect_prefect (07-13-2012)
Old 07-13-2012, 08:08 AM
HACKMUNCH's Avatar
0/11 sssss3892
I ran 4 of them in a ported wall in 64cft lol. I hate those subs, they will not do crap in a 4th but tear surrounds. Just go big ported.
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 07-13-2012, 10:52 PM
0/11 sssss2011
I was told 6th order for those would be really good. I can't do a flat wall with them. I could do a clam shell but really want to do a 6th. Jared says he has 52 cubes in his jeep. What kind of sizes should I do
Old 07-13-2012, 10:57 PM
villeza1's Avatar
0/11 ssssss544
3 18's or 4 15's.
2 AB 1100.1's
4 Tantric Sounds SHD 18's (PSI Recones)
4 Mechman Alternators
9 XS Power Batteries
24 Crescendo Mids/Highs
5 MB Quart Mids/High Amps
The Following User Says Thank You to villeza1 For This Useful Post:
4 hdc3 18s in 4th order good idea? vince79vette General Car Audio Discussion & Questions 7 05-07-2012 02:55 PM
Who has had HD/HDC3 in a 6th order? btsteinb Enclosure Discussion & Design Construction Help 2 03-05-2012 06:56 PM
Brandon's New Box - 6th order wall with 3x 18s sundownz (Sundown Audio) 107 01-31-2012 04:48 PM
Stacy's 2 IA 20.1s on 4 SS 18s IN a cool 6th order 98HOEONSIXEZ Car Audio Videos 11 09-11-2011 12:27 PM
