Need help with box for two DD 3515's - Car Audio Classifieds!
Old 07-06-2012, 01:39 AM
SuperDuper Elite Member
0/11 ssssss252
Default Need help with box for two DD 3515's
I have two DD 3515's running off two Sundown 1500's strapped. Right now they are in a box that was designed for two Sundown V1 Z 15's. The box is 6.4 cubic feet before sub displacement tuned to 34Hz with two 6" aero ports. I'm kind of disappointed in these subs so far. My Z's were as loud, if not louder. I think I need a bigger box for these....and I blew one of my Z's, so I'm a little scared to turn up the volume too loud.
My specs are:
Max 46" wide
Max 22" or so high (can play with this a little}
Depth can vary to the correct box volume, but I'd like to keep it as small as possible.
I guess I'd like to tune the box to 35Hz or so...I've heard DD subs do better with higher frequency ports, so I'm open to that also. If possible I could reuse these aero ports, or go for a slot port. I've read that these subs like a lot of port area.
My only other request is that the slot port can't be on the bottom of the box. I'd prefer the subs to face up, but doesn't matter too much.
I'd be willing to pay for a box design with cut sheets.
Any help would be great. Thanks!!!
Old 07-06-2012, 02:03 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7525
Feedback Score: 22 reviews
here is a dd1515 box i did.
2 DD 1515s - YouTube
pm me if you want some help. i have alot more boxes where that came from
The Following User Says Thank You to tony30cl For This Useful Post:
dwpjr (07-06-2012)
Old 07-07-2012, 01:59 AM
SketchUp Master
0/11 ssssss417
What vehicle are you working with? Ideally, you're going to want more volume and more port area. IMO, ditch the aeros and do a larger slot port, and up the total volume to 7.5-8ft^3 after all displacements. A 46" wide x 20" tall x 23-24" deep box will work in this case.
The Following User Says Thank You to RAM_Designs For This Useful Post:
dwpjr (07-10-2012)
Old 07-10-2012, 10:23 PM
0/11 ssssss252
So if I build a box out of 3/4" wood that is 46" wide, 20" tall, and 23" deep. What port area, and length would I need to tune it to 34Hz or so? I'd love to do subs facing up and one large port in the center of the box. Also is there anyway to get the height taller and the depth lower? MDF or Birch?
Old 07-11-2012, 05:33 PM
Hugh G. Rection's Avatar
0/11 sssssss88
are you just hellbent on saying it "tuned" at 34hz? just because you can say its mathematically tuned at a certain frequency, that still gives absolutely no indication of what the frequency response will be.
Old 07-11-2012, 06:07 PM
0/11 ssssss252
OK, so what is the proper way to describe a box with a port for a specific frequency? Isn't that the way all boxes are built? As far as I know, you build a box for a specific amount of air space and then a port of a certain size and amount of area in order to get a certain frequency.
Old 07-11-2012, 06:51 PM
0/11 sssssss88
that would be acceptable if all subs were identical. different driver have different needs, and different things that satisfy those different needs.
Old 07-12-2012, 01:38 AM
ltr450racer690's Avatar
0/11 sssss3414
I'd say 7 cubes with 3 6"s. plug one for daily. Just my 2 cent s
AUDIOTECHIX DEALER
DLP CUSTOMS SALES REP
The Following User Says Thank You to ltr450racer690 For This Useful Post:
dwpjr (07-12-2012)
Old 07-13-2012, 02:47 AM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
yeah you don't have enough port area brother
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
wtt 2 dd 3515's for 4 12's or big alt or batts Xtremelegend Car Audio Trader (WTT) 20 06-09-2011 02:06 AM
Dave the Box Guy Sub box for 2 15's 7'^3 @ 42hz for SUV 80$ OBO New England area hispls Wiring, Electrical & Other Installation Equipment 8 05-21-2011 02:43 AM
DD 3515's off a DDm1b 96jeepDD Car Audio Videos 8 02-05-2011 01:19 PM
18" trunk box dual corner loaded square port box Jacobbz206 Enclosure Discussion & Design Construction Help 0 06-20-2010 06:53 AM
