6th order guru's please help - Car Audio Classifieds!
Old 07-06-2012, 03:46 PM
spl_blazer
0/11 ssssss102
Default 6th order guru's please help
my 4-12's street box done a 155.4db sealed up at 49hz my latest 4th order is 154.1db at 47hz and a 152.8 @ 33hz with 4 hd15's but i have never attempted a 6th order here is what i have as far as volume in my 4th order i use win isd but not sure if its accurate for a 6th order i have 6.4 cubes sealed and 27 cubes in the front chamber how much will i need to change the ratio to get higher db's i can do 2-6" aeros in the rear chamber that would bring the rear into 35hz range but i know nothing about 6th orders.
Old 07-06-2012, 03:56 PM
Supergumby5000's Avatar
0/11 ssssss642
6th order with 6.4 cubes sealed?
You need to do some researching via google
Old 07-06-2012, 05:29 PM
spl_blazer
0/11 ssssss102
my 4th order has 6.4 cubes sealed i can make it a 6th order if it would work i know alot of people use a bigger rear enclosure but im throwing over 9k clamped at them right now in my 4th order . didnt know if i could get by with the smaller rear enclosure vented because i have plenty of power on tap.
Old 07-06-2012, 05:31 PM
spl_blazer
0/11 ssssss102
the main reason im looking into the 6th order is the american bass hd15 coils take the power just fine but the cones blow out around the surround in the small sealed enclosure.
4th order or 6th order sundown General Car Audio Discussion & Questions 2 06-14-2012 08:55 PM
4th order guru's unite! LyferXB9s Enclosure Discussion & Design Construction Help 85 09-20-2010 03:22 PM
