Help with Torres cut sheet - Car Audio Classifieds!
Old 07-08-2012, 04:48 PM
0/11 ssssss246
Default Help with Torres cut sheet
This is the box:
Subs forward, port forward on the driver side.
For the cut sheet would this work:
top, bottom: 53"x20"
back: 53"x32.5"
front baffles: 46.25" x32.5"
driver side: 19.25"x32.5"
passenger side: 17.75"x32.5"
port: 11.75"x32.5"
port extension: 10.5"x32.5"
Is the baffle thickness included in the physical port length?
Making a Cut Sheet e2theloc Enclosure Discussion & Design Construction Help 6 03-21-2011 02:09 AM
i need a cut sheet for 2 sa12's mineralgrey01gt Enclosure Discussion & Design Construction Help 0 12-01-2010 12:44 PM
i need a cut sheet or blueprint Austin175 Enclosure Discussion & Design Construction Help 2 11-20-2010 09:32 AM
Is my cut sheet right? SQL Monte Enclosure Discussion & Design Construction Help 4 06-29-2010 09:32 AM
need help w/ cut sheet? SacTownBully84 Enclosure Discussion & Design Construction Help 8 04-12-2010 09:00 AM
