box size - Car Audio Classifieds!
Old 07-10-2012, 07:48 PM
HOYT4X's Avatar
0/11 ssssss350
Default box size
idk how much air space the new subs i got need so i figured id ask
theyre the older style re se 10 dual2s and theres 3 of em imma be puttin em in a camaro on a soundstream rubicon2500.1 jus dont know how much space they need to perform well and not have issues cus they dont make em nemore
02 Zr2 S10
Singer 270 alt 1 run of 1/0 knuconcepts cca wire 2 black juice box in cab and a xs d3400 under hood
DC5k on a DD 818 in a 4.8 cube box tuned to 35hz powerbass 3xl comps in front doors and focal 1" silk dome tweeters in the a-pillars
Old 07-10-2012, 08:09 PM
niteryda's Avatar
im "E Thug" sukka
0/11 sssss3259
1-1.25 each i would imagine
2000 Pontiac Sunfire SE (239,000+ miles)
2 AQ3500D.1 (1 being used so far)
4 15" Nightshade v1
4 15" FI BTL N2 (1 being used)
3.5 net @ 29hz
3 crescendo 1000c4 (1 being used so far)
Bought From - Lots of people
Sold To - Myself
Traded With - DevinG17
Old 07-10-2012, 08:10 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
I do not know the recommended specs for those subs off the top of my head. but
is this box sealed or ported?
Old 07-11-2012, 02:41 PM
HOYT4X's Avatar
0/11 ssssss350
its going to be ported with a single 6inch aero
02 Zr2 S10
Old 07-11-2012, 04:29 PM
Hugh G. Rection's Avatar
0/11 sssssss88
ok, instead of blindly throwing numbers to you like alot of people will do, we should do this correctly. so with that in mind, we need a little info here.
what are you wanting to do with this? do you just want it loud on music, do you want it to sound good, or do you want it to put up a number on a meter?
Old 07-11-2012, 04:36 PM
HOYT4X's Avatar
0/11 ssssss350
loud on music and get low and i measure out a spot that i can work with and only have 2.55cuft to work with unless i make box do sum weird corners and subs r recoomended for 1.0 to 1.2 per
02 Zr2 S10
Old 07-11-2012, 04:39 PM
0/11 sssssss88
so your wanting high output. what is your definition of "get low"? to me, playing low is way down in the 20's, others may say that plaing in the high 30's is "low".
please define.
Old 07-11-2012, 04:41 PM
HOYT4X's Avatar
0/11 ssssss350
higher 20s low 30s cus dont need to blow out windows but wanna move sum air tho
02 Zr2 S10
box size Nolo91 (DC) 0 01-05-2012 09:46 AM
what size box for 15 and 18?? fyerbyrd22 General Car Audio Discussion & Questions 1 11-09-2011 03:48 PM
what size box for sa? fyerbyrd22 (Sundown Audio) 11 09-21-2011 05:39 PM
box size? thekernal123 Enclosure Discussion & Design Construction Help 0 03-14-2011 09:49 PM
box size help? luises14 Enclosure Discussion & Design Construction Help 2 08-12-2010 07:37 PM
