2 Sa8v2s on Aq1200D, Sealed box help - Car Audio Classifieds!
Old 07-11-2012, 07:43 PM
0/11 ssssss398
Default 2 Sa8v2s on Aq1200D, Sealed box help
Looking to build a sealed box for 2 sa8v2s running off a Aq1200D @ 1 ohm daily, listening to alot of rap ect.. so not sure if volume should change or not, im really not good at designing boxes, so any help would be appreciated, I just want to try these in a sealed box, ive already got a 2cf box @ 34hz.
Old 07-11-2012, 08:50 PM
0/11 ssssss398
Anyone?
Old 07-11-2012, 09:06 PM
99Bonney's Avatar
0/11 sssss6246
Did you not like the 2 cft box you have? Should sound good on rap if it's tuned correctly.
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 07-11-2012, 09:10 PM
0/11 sssss2429
Feedback Score: 46 reviews
.28ft^3 per sub
Displacement of .08ft^3 per
.28*2 + .08*2 = total box volume needed.
Old 07-11-2012, 09:14 PM
0/11 ssssss398
Originally Posted by brandes.cm View Post
.28ft^3 per sub
I get this from the Sundown site, but im not good with dimensions, and accounting for the divider in the middle for seperate chambers, or wood thickness ect.. And I like my box but i have a friend with a Scion Tc aswell and they have 2 10s in a sealed box on low power and it sounds fantastic, and the sound carries far.. Mine is loud and flexes alot, but you can 5ft away and hear nothing.
Old 07-11-2012, 09:18 PM
0/11 sssss3526
I thought Jacob said they dont recomend sealing these?
Team Flex Issues
Temp build
Jvf Custom ssx 12 on DSC 1500
Xs Power
Hertz/Image Dynamics
Old 07-11-2012, 09:20 PM
0/11 ssssss398
Ive not heard that, and he gives sealed specs on the site, but im not positive.
0/11 sssss2429
Do you want separate chambers? Torres box calc is pretty easy for both sealed and ports. What are your Max dimensions?
<<sent from your blown amp>>
4ozgloves's Avatar
0/11 ssssss309
You should want your car to sound great and loud inside not from a distance. Unless you feel the need to disturb other people like an *******.
Old 07-11-2012, 09:28 PM
0/11 ssssss398
Like 38w, 15D, 12H approx. This is what im working with now, I don't mind the sound but I can hear port noise. It does move alot of air though. ImageUploadedByTapatalk1342060074.880514.jpg
I keep my seats laid down, and its about 6" from the back hatch, and I still can put my seats up for passengers.
2-Sundown SA8v2s and Skar 1500.1?? SchnitzelBass General Car Audio Discussion & Questions 55 07-23-2012 05:47 PM
SA8v2s D4 jmkanek 8" Subwoofers 34 05-29-2012 04:43 PM
scion tc - pair of sa8v2s abraves4410 Build Logs 13 04-17-2012 02:59 PM
8s for sealed box ? sundownz (Sundown Audio) 21 01-03-2012 02:55 PM
Small Ported box or Sealed box Beatdown337 Enclosure Discussion & Design Construction Help 9 05-27-2010 03:17 PM
