box port torrez help please??????? - Car Audio Classifieds!
Old 07-12-2012, 06:33 PM
scfaust's Avatar
0/11 ssssss848
Default box port torrez help please???????
ok i have everything worked out but im putting subs up port to the side, but it must think im going out the other way cause it says i will need bends in port but i wont, my ? is will that make a difference?
AlphaDamp CLD Tiles - Get more sound deadening using less sound deadener
Old 07-12-2012, 06:52 PM
HOYT4X's Avatar
0/11 ssssss350
what are the dimensions
02 Zr2 S10
Singer 270 alt 1 run of 1/0 knuconcepts cca wire 2 black juice box in cab and a xs d3400 under hood
DC5k on a DD 818 in a 4.8 cube box tuned to 35hz powerbass 3xl comps in front doors and focal 1" silk dome tweeters in the a-pillars
Old 07-12-2012, 07:04 PM
98GCLimited's Avatar
0/11 sssss1921
Feedback Score: 29 reviews
It wont matter it still takes up the same volume
Old 07-12-2012, 07:08 PM
HOYT4X's Avatar
0/11 ssssss350
but no it should make a differance
02 Zr2 S10
Old 07-13-2012, 02:43 AM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
not if it still going to be the same port area as to what your putting into the program
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 07-14-2012, 10:20 AM
scfaust's Avatar
0/11 ssssss848
thats what i thought im just placing the port on the side of the box instead of in the front where it would need a bend LOL
help with port box a per and port area per ft lilsoccersully Enclosure Discussion & Design Construction Help 0 05-02-2012 10:04 PM
aero port box for 4 sa-8's, too much port? Dbmonster (Sundown Audio) 4 08-11-2011 03:08 AM
SPL box... Slot port? Port Tube? Kerf? CousinVin Enclosure Discussion & Design Construction Help 13 07-21-2011 02:41 PM
Single 15 dual slot port or dual L port box Hless421 Enclosure Discussion & Design Construction Help 3 09-26-2010 06:54 AM
18" trunk box dual corner loaded square port box Jacobbz206 Enclosure Discussion & Design Construction Help 0 06-20-2010 06:53 AM
