Please help with port! - Car Audio Classifieds!
Old 07-19-2012, 11:52 AM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
Default Please help with port!
im building a 4.5cuft box tuned to 34Hz for 2 twelves, it is sub forward, port forward and the port is in between the subs. The port came out longer than the box is deep so im trying to figure out how to do the port bend. The box is 22" deep and my port needs to be 21" deep, its 4.5" wide. So how the hell should the port look? Do i keep the port 4.5" wide on both bends either way? ( the port would be "T" shaped ) or does the port turn to 2.25" at the bends by splitting the difference? This has always been something i have wanted to ask.
The specs on the box if it helps at all.
Old 07-19-2012, 11:56 AM
k3n12ock's Avatar
Average Asian
0/11 sssss5963
Feedback Score: 49 reviews
Port should be 4.5" wide throughout meaning 4.5" width. 4.5" from the back of the box as well.
Old 07-19-2012, 11:57 AM
badmofo529's Avatar
0/11 sssss3329
i would like to add onto this. at the port bend, do you split the difference in port length? lets say a 24x6" port with 16" depth. would it turn and be 14" for both turns, or 7"
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 07-19-2012, 12:01 PM
Ryan1126's Avatar
0/11 sssss9178
that was my next question...
Right now from the beginning of my port to the back wall is 21.25". So i have to make the bend at 16.75" to keep the port 4.5" from the back wall, so then do i make both bends at 2 1/8" (by splitting the difference) or do i make them both 4.25"?
Old 07-19-2012, 12:20 PM
Ryan1126's Avatar
0/11 sssss9178
need answers so i can start building this damn box!
Old 07-19-2012, 12:42 PM
skartisu's Avatar
Clearly Louder
0/11 sssss1436
i would do a L port over the T port
what subs?
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
Old 07-19-2012, 12:43 PM
Ryan1126's Avatar
0/11 sssss9178
the guy wants the T port, most people said that when having the subs and port on the same side to do a middle port. So thats what im going with. The subs are Mamphis M5's
Old 07-19-2012, 12:46 PM
Matt3824's Avatar
0/11 sssss3754
Port width splits with a T-port
Old 07-19-2012, 12:47 PM
Ryan1126's Avatar
0/11 sssss9178
So each way goes 2 1/8"?
Old 07-19-2012, 12:50 PM
Matt3824's Avatar
0/11 sssss3754
Cartunz 3X show 6-24-2012 $500 for loudest non Port or Super Port score bdufner Competition Corner 2 06-16-2012 07:29 AM
