Torres question - Car Audio Classifieds!
Old 07-21-2012, 01:04 AM
arejayeye's Avatar
0/11 ssssss317
Default Torres question
Ok, there are two 2.5" ports and length is 26.75 (physical port length is 21"). Box depth is 25", Torres is telling me the ports bend. The ports would NOT bend, right?
Old 07-21-2012, 01:15 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
yes it would.
My game is legit,
Old 07-21-2012, 01:21 AM
arejayeye's Avatar
0/11 ssssss317
How? I thought your inner port wall is the physical port length (21")
Old 07-21-2012, 01:23 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
The length of the port is measured down the middle but the physical length is measured down the side. If the port is close enough to the back of the enclosure, the port will actually turn even though there is no physical material there.
Take for instance this enclosure below. Even though the physical port length is some 14.75" long, the port length is 18" because it makes a right turn.
Old 07-21-2012, 01:45 AM
arejayeye's Avatar
0/11 ssssss317
So in your example wouldn't the physical port length be 11.75 not 14.75? I'm sorry for all the questions, Im just tryin to understand!
Old 07-21-2012, 01:53 AM
666WMD's Avatar
0/11 sssss1307
Sorry, I was recalling the length before looking at the picture.
Yes, the physical length is 11.75. Add to that the 2 x .75 of the double baffle and you have 13.25, plus the further drop and right turn of 2" each, and .75 for the port material. That's 18" which is what Torres calculates.
(Torres says the physical length is 12.5, but it doesn't take into account one of the baffles. It assumes the second baffle sits inside the port panel)
Old 07-21-2012, 02:11 AM
arejayeye's Avatar
0/11 ssssss317
Thanks man! Will you make sure I have mine right?
Last edited by JayIsrael; 07-21-2012 at 02:13 AM. Reason: Wait, 21" including front baffle
Old 07-21-2012, 02:30 AM
666WMD's Avatar
0/11 sssss1307
The actual length of that port would be 25", not 26.75. I think I know what the problem is though.
Torres doesn't have an option for multiple slot ports, only aero ports. If you've tried to calculate it by using a 5" wide port and then splitting it when drawing it up, you'll have changed the frequency. Splitting a port will require a slightly longer length for duals over a single. Try it on this calculator and you'll see the difference -
Car Audio - PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES
Old 07-21-2012, 03:08 AM
arejayeye's Avatar
0/11 ssssss317
Yea when I enter 2 ports @ 2.5w x 13.5h with 4 cubes ( i am assuming it asks for net volume) it says length should be 31.08". What should I do?
Old 07-21-2012, 03:28 AM
666WMD's Avatar
0/11 sssss1307
Um, make them 31" long??
The only way you'll be able to get them shorter while having the same tuning will be to drop the port area, but then you risk increasing the vent velocity.
who uses torres box calculator? snyderd758 Enclosure Discussion & Design Construction Help 6 05-03-2012 11:06 PM
Does Torres account for... taylorpro Enclosure Discussion & Design Construction Help 10 08-20-2011 07:54 PM
Torres box calculator HELP!!! loudernu Enclosure Discussion & Design Construction Help 1 05-28-2011 06:59 AM
Need help with Torres 813thumper General Car Audio Discussion & Questions 5 03-27-2011 08:18 PM
Torres port length? Crazy4bass Enclosure Discussion & Design Construction Help 5 03-23-2011 11:49 PM
