this work? 2 Kicker comp 10s - Car Audio Classifieds!
Old 07-21-2012, 10:23 PM
0/11 sssss3842
Default this work? 2 Kicker comp 10s
Got fed up with waiting on a certain someone to get me designs so i DLed Torres and came up with this ^ this work ok? Just a daily box for a kid i work with in a reg cab ranger off a BOSS amp.
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 07-21-2012, 10:36 PM
0/11 ssss31258
unless the driver is less than 5' 5" tall, you need a wedge box for a ranger.
[in this case the word "driver" means the human behind the steering wheel]
Old 07-21-2012, 10:55 PM
0/11 sssss3842
Truck has Sparco seats so I can work with a rectangular box
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 07-21-2012, 11:09 PM
0/11 ssss31258
port up?
Old 07-21-2012, 11:19 PM
0/11 sssss3842
More than likely be out the driver side side firing
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 07-21-2012, 11:25 PM
0/11 ssss31258
ok.
yeah, it'll work.
port to the side has strange tactile loading properties... it could sound good or could sound bad.. no mediocre
firing the port up in the center of the box would yeild equal pressure inside the box and move the sound/air up by your ears. {and could load off the roof} but if the slider is open, the port would have pretty much full access to the world and not "load" well.
Old 07-22-2012, 05:53 AM
0/11 sssss3842
Originally Posted by iamsonic View Post
ok.
yeah, it'll work.
Solid rear glass so don't have to worry with that.
Firing out the side works well in my extended cab so figured I would try in a reg cab but firing up in the middle may work well too
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 07-22-2012, 06:27 AM
0/11 ssss31258
with that size port, you could build the box with a port out the side and a port out the center of the top {try each and then cap off the port you don't want to use}
7x Sundown SA-10s Random - May or May Not Work sundownz 10" Subwoofers 6 11-18-2011 02:43 PM
2 Kicker Comp 10s in box jmanpc 10" Subwoofers 5 09-14-2010 01:05 AM
10s thats will work good in 4 cubes and are cheap snoopysnooper General Car Audio Discussion & Questions 16 03-09-2010 01:09 AM
my idea for having the perfect comp song...will it work??? ugadawg131 General Car Audio Discussion & Questions 3 11-16-2009 07:32 PM
FS Kicker Comp 10 Anotherguy 10" Subwoofers 7 01-13-2009 04:30 PM
