need design/ cut list paypal ready - Car Audio Classifieds!
Old 07-22-2012, 12:50 AM
nmachado99's Avatar
0/11 ssssss391
Default need design/ cut list paypal ready
I have a 4 door blazer max dimensions 38w 22h 30d
Subs two fi btl n2 18's powered by two crescendo 3500's I'm not looking for numbers just wanna ground pound move some air. I have 25 in my paypal thanks
Old 07-22-2012, 01:11 AM
mylows10's Avatar
0/11 sssss2210
Feedback Score: 17 reviews
38 x22x30 is 12.34 cub ft internally
so you need 38 x22x 2 sheets frt and back
28.5 x 20.5 x2 sheets left and right sides
38 x28.5 x 2 sheets bottom and 1st top piece
38 x 30 final top piece double baffle
port is a 9x9 x 10
2 pcs 9" and 2 pcs 7.5 inches 10 inches long
port centered in the back of the box facing the rear gate ,need to make sure you leave room between the rear gate and box ,at least 6-8 inches if possible
Old 07-22-2012, 01:30 AM
nmachado99's Avatar
0/11 ssssss391
I have 4" to the gate with 30 what do you think about port up?
Old 07-22-2012, 01:32 AM
mylows10's Avatar
0/11 sssss2210
That will be fine. But subs up port back will sound the best and loudest
Old 07-22-2012, 01:40 AM
nmachado99's Avatar
0/11 ssssss391
28d gives me 11.47 what would you recommend for tuning?
Old 07-22-2012, 01:43 AM
mylows10's Avatar
0/11 sssss2210
Need to keep the box at 12^3 so keep the original specs you'll be happier with the out come and with doing the port as I suggested you can make port inserts to change the tuning easy
Old 07-22-2012, 01:46 AM
mylows10's Avatar
0/11 sssss2210
The boxand port I gave you is at 32 hrtz which should sound really good and low
Old 07-22-2012, 01:54 AM
mylows10's Avatar
0/11 sssss2210
Paypal is [email protected]
Old 07-22-2012, 02:01 AM
nmachado99's Avatar
0/11 ssssss391
Is there anyway you could Sketch this up and send to my email, and i can send the following. You think ill be fine with 4" between the gate?
Old 07-22-2012, 09:26 AM
mylows10's Avatar
0/11 sssss2210
I'll see what I can do and yes 4 inched should be ok
Want to buy a box design and cut sheet. Asap. Paypal ready. imadreamer1226 Enclosure Discussion & Design Construction Help 0 02-24-2012 12:16 PM
Can somone help me with a cut list? Ryan k. General Car Audio Discussion & Questions 1 08-10-2011 02:45 AM
Design Request (Paypal Ready) Slaughterhouse Enclosure Discussion & Design Construction Help 8 01-26-2011 08:01 PM
(FOUND) Need box design for sa-8...paypal ready fyerbyrd22 Enclosure Discussion & Design Construction Help 8 01-25-2011 08:38 PM
anyone want to design a box for me? paypal ready truckcap22 General Car Audio Discussion & Questions 2 04-08-2010 08:27 AM
