Construction Adhesive or Wood Glue?? - Car Audio Classifieds!
Old 07-25-2012, 05:14 PM
0/11 ssssss972
Feedback Score: 23 reviews
Default Construction Adhesive or Wood Glue??
Alright, I am in the process of walling my car. I am doing 2 layers all around, but I put baffle on in single layers for certain reasons, when I put the 2nd layer on...I thought about using construction adhesive because it does not run as fast as wood glue does.
Is the contact as good on construction adhesive vs wood glue?
Which is best for this application?
If you give me an answer please explain why.
Thanks!
Old 07-25-2012, 05:18 PM
silentbass's Avatar
0/11 ssssss345
wood glue would create a stronger bond between two pieces of wood and you can spread it evenly to avoid runs
Thanks!
TEAM HZ ADDICTION
98 Ford Explorer 2dr
caco refs: puredynamics
ca.com refs: 1ndatrunk, ent3rdadragon,psychoacoustics, Tez, Shizzzon, TeamSouthrnBass,Dadon,joe14,90accordman, thegreatestpenn, dcmcki
Me > Lord Van
0/11 sssss2831
The only construction adhesive I would personally use is PL premium.
Stay far away from liquid nails. That stuff, in my experiences, is total crap that doesn't bond nearly as well as PL or regular wood glue.
Team DOA
10 inches of terror
One DD 9510F + one kicker zx2500=150+ db
One Sundown SA-8 + 2 mb quart 2000's = 150+ db
-2006, 2007, 2009, and 2010 MECA World Champion
-2008 Bassrace 130-139.9 National Champion
Old 07-25-2012, 05:23 PM
0/11 ssssss972
Would you use PL premium over wood glue in this application?
Old 07-25-2012, 05:24 PM
0/11 ssssss972
Well, When this thing is running up and down...Even spred evenly it will still drip off the bottom while applying...I have a shitload of glue on my carpet already from this same thing last night.
Old 07-25-2012, 05:32 PM
0/11 ssss31258
suggestion..
either use "just enough" so the drips are small.
Or
buy the gallon container and a bucket... and a paintbrush. [I like doing this for Elmer's wood glue]
note: Elmer's wood glue cleans up with water.
{remove as much glue as you can before adding water to fabric/carpet or you'll be "painting" the fabric/carpet by trying to get the glue out}
Old 07-25-2012, 05:38 PM
0/11 ssssss972
Originally Posted by iamsonic View Post
suggestion..
Or
I use titebond II haha. I guess I have not even tried to clean any of it up, I have alot of work to do inside yet and know it is going to get filthy...But I figured if construction adhesive was good I would use that and save the mess, but it looks like wood glue is taking the cake.
Old 07-25-2012, 05:39 PM
Me > Lord Van
0/11 sssss2831
I always use wood glue whenever possible, because as stated it creates a chemical bond between the two pieces of wood.
PL does make a wood adhesive that I would try.
Team DOA
10 inches of terror
Old 07-25-2012, 05:40 PM
SPL Distribution Owner
0/11 sssss2983
I only use PL Premium around the inner and outer seams of street boxes.
Titebond II is what i use as the actual adhesive.
For my wall, I also use Titebond II in NON-Vertical applications.
That means.. gluing things to the floor or gluing the floor to something.
I also use Titebond II to glue multiple layers together too.
For everything else-
Vertical applications, oblong areas and inner\outer seams, I use Fasco 110.
If you want the "God" bond, you use Fasco 110.
Sometimes, i'll mix Titebond II and Fasco 110 together when gluing certain layers together depending on application.
Old 07-25-2012, 05:45 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
My only suggestion it per drill a few holes with screws in the top piece, spread the glue around with a brush, it helps prevent runs. And hustle you ass to get that top baffle on and screwed in.
You could try laying paper towel under if you can
Gorilla glue vs Gorilla Wood glue KNOTDUDE Tutorials & Quick References 22 05-10-2012 03:50 PM
Enclosure construction debate. Ami Creations General Car Audio Discussion & Questions 197 01-21-2012 01:34 PM
Baffle question. And construction help regizzle Enclosure Discussion & Design Construction Help 7 01-13-2012 09:01 PM
Shok Industries Website Under Construction headshok (Shok Ind) 9 08-29-2011 01:41 AM
what enclosure glue/adhesive? loud-n-low Enclosure Discussion & Design Construction Help 20 06-27-2011 12:02 AM
