Slot port - Car Audio Classifieds!
Old 07-25-2012, 06:30 PM
0/11 ssssssss5
Default Slot port
Dumb question but does a slot port have to bend or can it be staright. I typed my dimensions into Torres calculator and it says the port wouldn't even be long enough to bend. My box depth is 20 and the physical port length is only 16 which means it would stop 4 inches before the end of the box. Is this fine?
Thanks for any help in advance.
Old 07-25-2012, 06:41 PM
badmofo529's Avatar
0/11 sssss3329
Yuuuup
Sent from my inspire 4g using tapatalk
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 07-25-2012, 07:17 PM
0/11 ssssssss5
It would seem badmojo says thats ok(although I can barely tell through all the advertising) but could someone else chime in just so I can be sure I am doing it correct before I add the port on my box.
Old 07-25-2012, 07:20 PM
0/11 sssss1943
if your box depth is 20" then isnt it 18.5 internally?
Old 07-25-2012, 07:36 PM
0/11 ssssssss5
I typed into the Torres calculator the height of the port is 13.5 the width is 3.25 and the length is 20. It says the physical port length is 16 inches. So that means I don't have to curve the port?
Old 07-25-2012, 07:37 PM
0/11 ssssssss5
ooooo I see what you mean Talon you are correct. See thats why I have to ask these dumb questions.
slot port or aero port tommytee General Car Audio Discussion & Questions 3 08-07-2011 10:17 PM
SPL box... Slot port? Port Tube? Kerf? CousinVin Enclosure Discussion & Design Construction Help 13 07-21-2011 02:41 PM
~143^2 Aero Port vs 235^2 Slot Port for 21 net cube enclosure VOPA1 Enclosure Discussion & Design Construction Help 6 12-02-2010 05:03 PM
Help with a BP, slot port or square port for 2nd row 4th order bandpass wall 46panel General Car Audio Discussion & Questions 7 08-24-2010 09:32 PM
