Question about 4th order designs - Car Audio Classifieds!
Old 07-31-2012, 01:12 AM
Brand New Members
0/11 ssssssss3
Default Question about 4th order designs
Alright, in my quest to eliminate rattle in my Dodge Charger I've decided to do a forward firing box sealed from the trunk. The sub is a single Fi Q 12" powered off an MB Quart 1500D. It will be in a 2 cubed box tuned to 32 hz. However, I'm intrigued by what I've read about 4th order bandpass boxes. I'm thinking of having one built and firing the port through the rear factory 8" oem sub opening directly into the cabin. With this set up, will it still have to be sealed off from the trunk to eliminate rattles? I guess what I'm asking is will the bass be completely channeled through the port. That way all I would have to do is seal the port itself off from the trunk into the cabin?
Old 07-31-2012, 01:17 AM
perfect_prefect's Avatar
0/11 sssss1265
yes, that would eliminate the majority of your trunk rattles, you still may have some but would be very minimal compared to what you have now
Enough to do a 3 minute average on music of 150db
Old 08-04-2012, 04:03 AM
Brand New Members
0/11 ssssssss3
Okay thanks, another question. With a 4th order box that's 1 cube sealed and 2 cube ported, if i use a 7"x7" square port how long does it have to be for it to be tuned to 50Hz? How long would the port have to be for a 6" aeroport?
4th order designs littleharv93 Enclosure Discussion & Design Construction Help 27 06-05-2012 07:21 PM
4th order and qts question jondatruth Enclosure Discussion & Design Construction Help 3 02-18-2012 11:23 PM
4th order tuning question treylittlefield Enclosure Discussion & Design Construction Help 5 08-07-2011 02:07 PM
Another 4th order question.. tez4life General Car Audio Discussion & Questions 1 03-17-2011 06:21 PM
4th order ratio question constantprojects General Car Audio Discussion & Questions 6 02-11-2011 06:08 PM
