infinite baffle help - Car Audio Classifieds!
Old 07-05-2009, 07:21 PM
Default infinite baffle help
ok I made a IB for my mustang just to see if I like it and even with it needing to be sealed off it sounds awesome with 2 infinity reference 10's it actually flexes my quarter panels and roof and made my fender that was sitting on the front fall off
so here is what I was thinking
1/2" birch over the entire back divider
fiberglass it and paint it
then add 3 of these in there being hometheater subs they should work decent for this shouldn't they?
power will probably be around 400 watts I just want a flat responding system from 20-60hz
Parts-Express.com:Morel CAW938 9" Cast Frame Woofer | caw938 mw-265 mw-266 mw265 mw 265 6 inch woofer mid woofer midbass 6" woofer poly cone shielded woofer
Old 07-05-2009, 07:26 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
Those should be okay, whats wrong with keeping the infinities if they sound good?
My Car, My Ears.
Old 07-05-2009, 07:28 PM
they don't like the power that well they get stinky and they don't sound as clear as I want plus they are a little beat up so those morels should be fine for a car I don't like putting HT stuff in there but the infinite baffle setup was originally for home theater right
Old 07-05-2009, 07:33 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Well HT IB is implemented differently. Also a HT driver doesn't necessarily have all it takes to make it as an IB driver, those appear to have good specs for IB, but in my IB experience specs don't always translate into real word performance.
My Car, My Ears.
Old 07-05-2009, 07:36 PM
well I have never done one before I have been looking them up alittle and have seen the huge ass sealed box and then others where the put a baffle in a door way and use the room for the box so I'm basically just guessing and hopeing it comes out good I have a lot to seal and deaden but I think it would be hard to screw a IB up with the right drivers
Old 07-05-2009, 08:01 PM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Pretty much just need the correct driver.
My Car, My Ears.
Old 07-05-2009, 08:03 PM
I noticed my divider from the trunk to the back seat area deff needs to be stronger I lose all the lows once it starts to move around abunch I may go see what I can do to brace that up thinking of welding sheet metal around the opening to make it smooth anyway
Old 07-05-2009, 10:32 PM
anybody else have anything to say?
Old 07-05-2009, 10:46 PM
grimreper912003's Avatar
Hook me up with dat JL
0/11 sssss6190
Use 1/8" bar stock to strengthen it.
Old 07-05-2009, 11:22 PM
I"m probably gonna use flat stock like 1/8" x4" or something the sheetmetal over it
Infinite Baffle? please explain... aturcotte127317 General Car Audio Discussion & Questions 33 06-16-2009 05:10 PM
baffle and deadner q's Snwbrdr1 General Car Audio Discussion & Questions 8 05-29-2009 02:15 PM
chaos, defined; infinite possibility Nudels New Member Orientation 18 05-15-2009 04:36 PM
Not quite an enclosure but a baffle... nismos14 Enclosure Discussion & Design Construction Help 44 11-02-2008 09:56 PM
