double baffle or bracing? - Car Audio Classifieds!
Old 08-05-2012, 01:52 AM
0/11 sssss1182
Default double baffle or bracing?
I am looking for input on which you do and why?
Also, when do you decide to do it? ( such as different variables to box size, power the sub(s) will be getting, etc.)
I have used both methods in the past bu have no bias either way. Just curious and trying to decide which on my enclosure.
Thanks
Dustin
Powered By MAXXSONICS
Old 08-05-2012, 01:58 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Both. Double baffle only strengthens one panel but also supports the subs better, reducing the stress on the baskets from filling in the big holes in the panels. Bracing holds the 2 opposing panels together but does nothing for the subs.
Old 08-05-2012, 02:39 AM
arejayeye's Avatar
0/11 ssssss317
^^^x2
Old 08-05-2012, 11:49 AM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
I did both! I did a front double baffle, and then did a 1 1/2" dowel brace from the double baffle to the back wall of the box, and from the bottom of the box to the top of the box.
Box is the sturdiest one Ive ever had.. knocking on it, it sounds like concrete. lol My other box sounds all flimsy when I tap on it with my hand.
Old 08-05-2012, 12:27 PM
0/11 sssss1182
How big of enclosures were these? And what size woofers were used ( diameter and weight)? Also what kind of power was going to the woofers in the enclosure?
Old 08-05-2012, 12:30 PM
davidrforbus's Avatar
0/11 sssss6030
Feedback Score: 59 reviews
Most of the time, I prefer double baffle and depending on the box design you may or may not need braceing. My box for my oa12's has the port acting as a brace.
Old 08-05-2012, 12:36 PM
Prohibited Sellers/Buyers
0/11 sssss1326
this, for most smaller/ daily builds with slot ports the port will be plenty of bracing. but when in doubt i say both.
Old 08-05-2012, 12:47 PM
Mr.G6's Avatar
0/11 sssss4614
i almost always double baffle and brace a box.. no matter what subs or power...
bc seems like i always have to mount my amps on the box bc of room restrictions n such..
so i never take the chance for anything to flex or vibrate
2000 Gmc Sonoma ext cab
Old 08-05-2012, 12:52 PM
I hate bracing in spl type enclosures.
Old 08-05-2012, 12:55 PM
Loyal Member
0/11 sssss2152
Feedback Score: 35 reviews
I like to use the port as bracing. Center a slot port and it links the top and bottom of the box nicely.
I'm just gonna ask my landlord to hold the car up while I take the tires off. I mean, she's old and all but should be okay.
Aeroports & Double Baffle OldSchoolRF General Car Audio Discussion & Questions 5 03-25-2012 03:19 PM
double baffle for one hdc318? MERQUE General Car Audio Discussion & Questions 1 11-30-2011 09:11 PM
Double baffle help jhg33k Enclosure Discussion & Design Construction Help 3 07-12-2011 02:05 AM
Double Baffle Question?? tntahoe General Car Audio Discussion & Questions 2 05-02-2011 01:29 PM
2" screws for double baffle? Mgcauctions09 General Car Audio Discussion & Questions 1 04-25-2010 06:45 PM
