Port question - Car Audio Classifieds!
Old 08-06-2012, 04:32 PM
0/11 ssssss216
Default Port question
I just picked up a pair of 15" XL M1's going to be reconing them to .7 coils and running them off of a Crescendo 3kwp for now but plan on moving up in power later. I currently have a pair of LVL 4 M1's running off of the same amp installed now the car is a 2007 impala, with this set up i ported the rear deck with 4 4" aero's tuned to 32 this box is to small for my new subs going to be building a new box for them and i would like to port the rear deck with a square/slot port to get a little more port area thought this would be better than trying to use the areo's again due to the flares i can only get the four in the deck, box is going to be 17hx36wxd27 this going to give me 7.89 gross 7.43 after sub displacement i want to tune this to 33HZ but i'm not sure how to calculate port area for a square/slot type port need some help with this any and all help is appreciated. Going to be building this in the trunk and the port will be partially external.
Old 08-06-2012, 04:56 PM
villeza1's Avatar
0/11 ssssss544
Is that external dims, b/c I got 9.56 from your dims?
2 AB 1100.1's
4 Tantric Sounds SHD 18's (PSI Recones)
4 Mechman Alternators
9 XS Power Batteries
24 Crescendo Mids/Highs
5 MB Quart Mids/High Amps
Old 08-06-2012, 05:02 PM
villeza1's Avatar
0/11 ssssss544
Gross I got 7.89
2 AB 1100.1's
Old 08-06-2012, 06:00 PM
0/11 ssssss216
Gross 7.89 external 7.43 after sub displacement.
Old 08-06-2012, 06:07 PM
villeza1's Avatar
0/11 ssssss544
What's your desired width of the port?
2 AB 1100.1's
Old 08-06-2012, 08:05 PM
0/11 ssssss216
Port width i was thinking 8".
Question about port up vs port back 916slapin Enclosure Discussion & Design Construction Help 8 03-14-2012 08:14 AM
port question joselito318 General Car Audio Discussion & Questions 12 01-19-2012 12:42 PM
port question kush killer Enclosure Discussion & Design Construction Help 13 09-28-2011 12:56 PM
Port question Wisneaky General Car Audio Discussion & Questions 2 08-30-2010 04:17 PM
port question fiBl18 General Car Audio Discussion & Questions 6 06-18-2010 03:37 PM
