4th order design for 3 american bass xfl 10s - Car Audio Classifieds!
Old 08-06-2012, 08:21 PM
kickerlivinloud's Avatar
0/11 ssssss162
Default 4th order design for 3 american bass xfl 10s
i need a little help with a box design for a 2001 honda accord 4th order trunk build the max size is 36" deep-14" high-36" wide what ratio would be best for 3 american bass xfl 10s d4s for the most output how much sealed and ported and about how much port
Old 08-06-2012, 08:33 PM
villeza1's Avatar
0/11 ssssss544
Those subs aren't really suited for a 4th order.
But I'd do 0.5-0.8 cbft for each woofer so, 1.5-2.4 sealed total. If you want more musical and utilize minimal air space, 2:1; more output sacrificing more air space, 3:1.
SA-10's and 12's would work better.
2 AB 1100.1's
4 Tantric Sounds SHD 18's (PSI Recones)
4 Mechman Alternators
9 XS Power Batteries
24 Crescendo Mids/Highs
5 MB Quart Mids/High Amps
Old 08-07-2012, 09:37 PM
0/11 ssssss162
what would be the best setup then for those 10s to yeild closet to a 150db
Old 08-07-2012, 09:47 PM
villeza1's Avatar
0/11 ssssss544
You're just going for numbers?
Obviously a smaller ported enclosure ported freq near peak freq. Or a horn enclosure with tuning relatively the same.
If it's the best of both worlds i.e. daily/SPL, then a quasi 6th order BP.
How much air space can you afford to lose?
2 AB 1100.1's
Old 08-07-2012, 09:55 PM
mads10bass's Avatar
NOT LOUDER THAN YOU :(
0/11 sssss7335
Feedback Score: 36 reviews
please tell me why the xfl is not suited for a 4th order?
Sent from my DROIDX using Tapatalk 2
WOW
Old 08-07-2012, 09:57 PM
mads10bass's Avatar
0/11 sssss7335
I was told in a trunk get closer to a 1:1.5 ratio with the xfl 10s. .6 sealed each and 1 ported each
WOW
Old 08-07-2012, 10:00 PM
villeza1's Avatar
0/11 ssssss544
Qts .398
xmax 19
Not saying it won't work, but it would work better in a different type of enclosure. I'd do a 6th order instead of a 4th.
2 AB 1100.1's
Old 08-07-2012, 10:02 PM
mads10bass's Avatar
0/11 sssss7335
so the 10 is the only one then?
WOW
Old 08-07-2012, 10:05 PM
villeza1's Avatar
0/11 ssssss544
What do you mean?
2 AB 1100.1's
Old 08-07-2012, 10:08 PM
Kelocyde's Avatar
0/11 ssssss190
Not the only one.
I think he means the only sub that would work?
Why don't you download Win ISD Beta and input a few drivers?--it will tell you their recommend enclosure and you'll get the idea of what t/s parameters are for if you don't already know.
american bass xfl playin young jeezy...bass demo..look at the reactoin jpsaudio General Car Audio Discussion & Questions 6 11-17-2012 06:28 PM
American Bass Ford Explorer 4th order (one of my current up and coming projects) ssaudio Build Logs 27 10-25-2011 11:47 AM
New box design? 4 American bass XFL 15s 4x4xfl General Car Audio Discussion & Questions 12 05-11-2011 07:37 PM
2 american bass xfl 10s in 4th order or ported? mads10bass General Car Audio Discussion & Questions 4 04-03-2011 03:51 AM
[SOLD] 16 american bass xfl 10s Biggtyme6474 10" Subwoofers 133 01-23-2011 11:52 AM
