4th Order for Z v.3 12" - Car Audio Classifieds!
Old 08-08-2012, 03:28 PM
0/11 ssssss461
Default 4th Order for Z v.3 12"
I've attached a 4th order design for a Z v.3 12" that I picked up recently. Wondering what anyone's thoughts are on this. It's .75cf sealed and 2.25cf @ 50hz with 60in^2 of port. Does anyone have experience with this particular sub in a 4th order?
The image I attached is ridiculously small. Here's a link to the full-size version => https://www.dropbox.com/s/mu0uc7j673...zv3_12_4th.png
Old 08-08-2012, 03:31 PM
0/11 ssssss106
that's a weird looking forth order
Old 08-08-2012, 03:36 PM
badmofo529's Avatar
0/11 sssss3329
How so?
Sent from my inspire 4g using tapatalk
'97 chevy s10
-kenwood x994
-image dynamics ctx 6.5 cs
-2 aq sdc 2.5 15's
-aq 4x90
-aq 1200
Old 08-08-2012, 03:38 PM
0/11 ssssss461
I've seen several like that. Makes the best use of space for single sub 4th orders. My biggest concern at this point is if these subs work well in 4th orders. I'm pretty confident the design is not bad. Still would like some input from community!
Ronmeister's Avatar
0/11 ssssss791
Sealed section might be a tad small. What kind of passband and peak tuning are you looking for?
Old 08-08-2012, 03:42 PM
0/11 ssssss461
I'd like to peak around 50hz. Would like to be fairly flat from 30-70hz.
Old 08-08-2012, 03:43 PM
perfect_prefect's Avatar
0/11 sssss1265
they do work well in 4th orders, a buddy of mine has 4 z3 18's in a 4th wall, he made his have a huge sealed side and they do very well in it.
Enough to do a 3 minute average on music of 150db
Old 08-08-2012, 03:47 PM
0/11 ssssss461
Does the fact that the 18" version works well mean the 12" will? I'm not sure. Based on that statement, maybe I should do something more like 1cf sealed, 2cf ported. Go with a 2:1 ratio with a slightly larger sealed section over a 3:1 ratio with a smaller sealed section.
Old 08-08-2012, 03:50 PM
0/11 ssssss106
Originally Posted by badmofo529 View Post
How so?
personally too many turns. I tried a box like that and it farted, but I had only 1inch opening on an sa-8. 4" looks better and might work okay, just risky is why I said weird.
Old 08-08-2012, 03:53 PM
0/11 ssssss461
There's only one 180* turn. This seems to be a highly debated subject. I've heard some people say they've built a box with three 180* turns and it sounded great, and I've heard others say that one 180* turn is too much.
4th order for SX 15" taylorpro Enclosure Discussion & Design Construction Help 2 10-21-2010 09:53 AM
Fi audio 15" Q 4th order help rawlins87 Enclosure Discussion & Design Construction Help 2 08-11-2010 09:34 AM
4 18" 4th order... Scapelli21 General Car Audio Discussion & Questions 25 07-02-2010 05:32 PM
10" 4th order grimreper912003 Enclosure Discussion & Design Construction Help 12 01-28-2010 10:40 AM
2 10"s 4th Order rmzsuzuki89 Build Logs 36 12-06-2009 08:56 PM
