kerf port length - Car Audio Classifieds!
Old 08-08-2012, 07:15 PM
whitetrash84's Avatar
0/11 ssssss125
Default kerf port length
Looking at SSA's recommended enclosure for a 12" Xcon I picked up. I'm wanting to do a kerf on both ends of the port, say an 8" diameter (4" radius).
My question is how much port length will I need to add to keep tuning around 30-32 Hz?
Old 08-08-2012, 07:40 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Half of the radius is your effective port length. If you have a 4" radius, that flare only adds 2" of port length.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
whitetrash84 (08-09-2012)
Old 08-09-2012, 02:35 AM
0/11 ssssss125
Alright, thanks man!
Old 08-09-2012, 02:37 AM
0/11 ssssss125
Is it worth it to kerf both ends of the port?
The Following User Says Thank You to whitetrash84 For This Useful Post:
Ricksi30 (08-09-2012)
Old 08-09-2012, 02:39 AM
Ricksi30's Avatar
0/11 ssssss997
You probably won't hear a difference, it looks nice though.
Head unit: Kenwood Excelon KDC-X996
Front stage: Alpine Type X mids Vifa Neo 1" silk tweeters
Component amp: PPI Bk800.4
Subs: SSA XCON 12's in 4.5 cubes tuned to 34hz
Sub amp: PPI Bk1300.1
Team SSA
Old 08-09-2012, 07:16 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Having such a large kerf on the inside may change the dynamics of the enclosure. With that design you linked, if you put a 4" kerf on the inside end of the port, the kerf would end about 8" from the baffle. Effectively that would create another chamber inside the enclosure. Since the sub is in that chamber, it might act like a ported chamber with 8"w x 13"h x 0.75"l port. Just guessing I think it would be ok if the kerf diameter didn't exceed half of the depth from the baffle to the port, but a smaller kerf or just a flare would be as effective in reducing port noise and less likely to interfere with the enclosure dynamics.
The Following User Says Thank You to 666WMD For This Useful Post:
Old 08-09-2012, 09:22 AM
0/11 ssssss125
Alrighty then, I'll just make a small 45 on the inside or maybe just a 3/4" round over on that edge.
Kerf port? CousinVin Enclosure Discussion & Design Construction Help 10 01-01-2012 02:32 AM
Port Length vs. Physical Port Length nicholask1993 Enclosure Discussion & Design Construction Help 28 10-21-2011 04:01 PM
SPL box... Slot port? Port Tube? Kerf? CousinVin Enclosure Discussion & Design Construction Help 13 07-21-2011 02:41 PM
Kerf Port SKDooley Enclosure Discussion & Design Construction Help 17 12-24-2010 02:30 PM
