6th order bp port area, help! - Car Audio Classifieds!
Old 08-09-2012, 02:34 PM
0/11 ssssssss7
Default 6th order bp port area, help!
ok so i have been searching around and have found that for the rear chamber you should use about 6 - 8in2 of port per cube. and for the front chamber about 18 - 22in2 of port per cube. is this correct?
i am using 2 10's and i have been using winlsd and everything is looking good so fa. i have the rear chamber all figured out but the front chamber is smaller than the rear. 3.5ft3 @ 32hz and 1.8ft3 @ 59hz is what models the best on winlsd, but because the front chamber is 1.8ft3 the port will be pretty small. were talking 36in2 of port and im thinking that will choke the 10's. any help? thanks
Old 08-28-2012, 10:52 AM
0/11 ssssss211
Use the vent length that will maintain vent velocity under 10% mach, which is approx. 35m/s. If it is larger than this, then THAT is what will tell you if the woofer is being choked or not.
I don't do the whole "so many sq in per cube" thing ; I work with actual speaker requirements. The system needs to be modeled with the right amount of power. That tells you if you have enough port area or not--by looking at vent velocity.
Old 08-28-2012, 10:57 AM
Micksh's Avatar
0/11 sssss2596
^^^Someone who gets it here...
My Youtube page
Astro build log link
Old 08-28-2012, 12:16 PM
0/11 ssssss211
Thanks. I had left car audio for a long time to focus on other things. Not that I was a competitor or anything like that, but I started building boxes when I was 13-14 yrs old and started with two books, Ray Alden's Speaker Systems, and Vance Dickason's Cookbook, with a basic 4 function calculator, volt/ohm meter, resistors, and a signal generator. That was all I needed to accurately determine (within about 5%) all the necessary T/S parameters, and even VERIFY actual enclosure tuning. I would even call my local weather center to ask about current temperature/humidity/baro. pressure in order to be able to calculate air density to accurately determine the speed of sound for the Vas calculation. I even had to discover on my own how to raise a number to a decimal exponent WITHOUT having a convenient "x" button, or a square root button on my calculator. Ya'll should try doing that without help from google.
Now a days, life is much easier with computers and hardware like the WT3/DATS. No offense to whoever likes "sq in per cube", but it just doesn't jive. It's not like you can arbitrarily CHOOSE to make a box 1 ft and ONLY use 14 in for a massive 15" subwoofer that can move 1"+ each way. Same thing goes the other way--you can't just make a 80 ft box for a 12" woofer and accurately reason you need, say, 12in for EACH cubic foot, especially when the woofer can only do 3/4" peak-to-peak excursion--you'd end up with a ginormous 960 in of port area--equivalent to twelve 12" woofers! Ridiculous! More excursion for a given woofer diameter simply requires more port area to keep vent velocity low to avoid port compression losses, plain and simple. It's been in the books for decades and nothing has changed about the rules of physics.
The Following 2 Users Say Thank You to guitar maestro For This Useful Post:
ridintwo6s (08-28-2012), SPLEclipse (08-28-2012)
Old 08-28-2012, 12:28 PM
Micksh's Avatar
0/11 sssss2596
I think for the average kid with a ground pounder box in the trunk or an SUV, the sq in per cube thing will get them at least somewhat close....but it obviously doesn't take full advantage of the woofer's capability...it just won't get the full potential in something like an SPL system.
My Youtube page
Quasi 6th Order Bandpass port orientation... quagmire Enclosure Discussion & Design Construction Help 10 06-07-2012 10:23 PM
port area 4th order constantprojects Enclosure Discussion & Design Construction Help 28 05-14-2012 11:39 PM
how much port area per cube for a 4th order laextreme5 General Car Audio Discussion & Questions 20 01-19-2012 11:14 PM
4th order port through rear deck need design help, and build help in MN or IA area maddog2099 Enclosure Discussion & Design Construction Help 6 05-21-2011 09:19 PM
