HELP me build a non-wall 4th - Car Audio Classifieds!
Old 08-12-2012, 02:22 AM
KEVGNAR's Avatar
0/11 ssssss928
Default HELP me build a non-wall 4th
I have a 1997 escort wagom and would really like to build me a non-wall 4th,
I have two NSv1 12" and currently one skar1500.1(another asap lol)
I was thinking a 3:1 with 1.5 sealed and 4.5 ported, how do i figure port velocity? I dont feel like going through hack 10000 post 4th thread to find it
My ideal dims would be; 36wide 14.5 tall 24long but that can change. Im going to post what id like it to look like in a few but any and all help and input, (cough,hack,cough) would be great
Even though this is definitely not built for numbers, demos speak a thousand words...
1990 Oldsmobile Cutlass Cruiser
Old 08-12-2012, 02:36 AM
KEVGNAR's Avatar
0/11 ssssss928
This is how i would like to build it, Port up
Old 08-12-2012, 09:19 AM
Port velocity is calculated just like you would with a ported box. Plug in the dimensions and port size of the vented side. I wouldn't worry about it too much though, as 4th order ports typically have plenty of port area (HACK recommends 1/2 of cone area for port area).
Old 08-15-2012, 03:59 PM
KEVGNAR's Avatar
0/11 ssssss928
Here are the final sketch ups of the box, its a perfect 3:1 with like 120 port area.
Each driver will have 4.5ported and 1.5sealed EACH, my next Q is how deep should i make my port? It will be removable as you can tell and can be either external or internal
LET ME KNOW WHAT YOU THINK OF THE DESIGN!
Old 08-15-2012, 10:37 PM
KEVGNAR's Avatar
0/11 ssssss928
Any input?? Has anyone ever tried something like this?
Old 08-15-2012, 11:17 PM
0/11 ssssss816
Feedback Score: 22 reviews
without any dimensions it looks as though from the picture the port will end up being way too long for a 4th order if it extends over halfway through the box, plus the length of the bend. I'm about to attempt my first bandpass box ported through the trunk, so we'll see how it goes. Good luck!
Old 08-16-2012, 01:55 AM
villeza1's Avatar
0/11 ssssss544
Only because the goal is to get sealed res and loading wall port tuning around 45-50 hz. The higher you tune, the more port area you need.
2 AB 1100.1's
4 Tantric Sounds SHD 18's (PSI Recones)
4 Mechman Alternators
9 XS Power Batteries
24 Crescendo Mids/Highs
5 MB Quart Mids/High Amps
Old 08-16-2012, 01:57 AM
villeza1's Avatar
0/11 ssssss544
Port area should be a tad bit smaller if you want to follow HACK's advice. 113in^2.
2 AB 1100.1's
Old 08-16-2012, 02:09 AM
KEVGNAR's Avatar
0/11 ssssss928
It just about right on, i will be making a removable port so that will be adressed if need be
Old 08-16-2012, 02:24 AM
Matt3824's Avatar
0/11 sssss3754
With that power, or even with 2 1500s, I'd make the sealed side bigger.
1995 Honda Civic coupe 4th order wall build Russla Build Logs 14 07-27-2012 06:18 PM
ported wall or 4th order wall jmkanek Enclosure Discussion & Design Construction Help 12 05-12-2012 09:37 PM
4th order wall? tommytee General Car Audio Discussion & Questions 16 01-27-2012 04:01 PM
4th order wall? Russellabt General Car Audio Discussion & Questions 0 05-21-2011 07:50 PM
The Jeep : 4th Order No-Wall Build sundownz (Sundown Audio) 30 02-14-2011 05:44 PM
