This box or that box (pretty pictures inside!!) - Car Audio Classifieds!
Old 08-12-2012, 11:10 PM
Default This box or that box (pretty pictures inside!!)
...sorry, I lied. They pictures aren't at all pretty.
I'm probably going to be doing (6) 12"s in my 4th order soon. I'm trying to decide if I should do subs stacked vertically with the port behind the drivers seat or subs firing up with a top port.
The first pic is from the top looking down. The enclosure has to narrow where it goes between the wheel wells so I'll have to invert the very back subs.
The second pic is from the side (hence the poorly drawn seat for reference) and shows the subs lined up on the bottom of the enclosure. The advantage to this one is that the bottom of the shell is flat, so I feel they will have better loading. The probably is that I rarely ever see anyone do this (I think someone here did it with two Crossfire 18's in a TC), so I don't know if I should try it.
Either one will be about 7 sealed and about 18 ported at 45hz.
Any thoughts/ideas?
Old 08-13-2012, 05:01 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
4 OA15's in a 4th configured as in the second drawing.
smfonic's 4t order rebuild - Realm of Excursion
Old 08-13-2012, 06:05 AM
Micksh's Avatar
0/11 sssss2596
1st one... Stick with the driver's side port... Been proven... Look at Scott's Tahoe, very similar type design. I'd stay away from the top port design. My $.02...
My Youtube page
Astro build log link
Old 08-13-2012, 11:27 AM
LOL...I like how he resined the box and then put textured paint over the resin. :facepalm:. Nice install though!
Yeah, I've seen Scotts. When installs are that good I have a hard time even thinking about myself doing something like that, lol. Do you think it will be an issue having the back subs (the inverted ones) firing directly into the side of the enclosure? There will be about "4-5" between the cone and the wall, so I hope that's ok. Another question: should I just invert all of the subs or do you think it will be OK to run 4/6 with the basket in the sealed side and the other 2 inverted? Thanks!
Old 08-13-2012, 05:19 PM
Micksh's Avatar
0/11 sssss2596
Shouldn't matter, that 4-5" is probably a little more than the top subs have in the Astro...and it doesn't matter inverted or not, but I probably would just for cooling purposes, but like I said, it's really up to you...
My Youtube page
The Following User Says Thank You to Micksh For This Useful Post:
SPLEclipse (08-13-2012)
Old 08-13-2012, 05:32 PM
villeza1's Avatar
0/11 ssssss544
Sry to thread jack...
Micksh, what if you were doing a c-pillar 4th behind the second row seats. Wouldn't the driver side port get choked off therefore lacking in output? Wouldn't a top port be better for output? Or would a driver side port still be louder even thought the second row seat is blocking 1/2-3/4 of the port? This would be for a daily setup...
2 AB 1100.1's
4 Tantric Sounds SHD 18's (PSI Recones)
4 Mechman Alternators
9 XS Power Batteries
24 Crescendo Mids/Highs
5 MB Quart Mids/High Amps
Old 08-13-2012, 06:27 PM
That makes me feel a million times better. Thank you!
Old 08-13-2012, 06:33 PM
Micksh's Avatar
0/11 sssss2596
Probably wouldn't be too bad in a c-pillar...if Hack sees this, he may be able to answer it better honestly.
My Youtube page
Old 08-13-2012, 06:38 PM
villeza1's Avatar
0/11 ssssss544
Yeah, I figured it would be better to have the port above above the seats.
2 AB 1100.1's
Old 08-13-2012, 06:41 PM
Micksh's Avatar
0/11 sssss2596
Actually, just talked to Hack, he said he likes to use center port in c-pillar builds, but if you are chasing numbers, stick with driver's side port still....he said avoid the top port.
My Youtube page
enclosure phasing help plus box build pictures myjaja Enclosure Discussion & Design Construction Help 4 03-28-2012 05:46 PM
lights for inside of box treylittlefield Enclosure Discussion & Design Construction Help 4 11-22-2011 10:25 PM
A few pictures of my other hobbie BMX. (BEWARE SASQUATCH PICTURES INSIDE) dat517boi Sports and Fitness 6 12-20-2010 06:30 PM
Best L.E.D.s for inside a box? oxsign General Car Audio Discussion & Questions 8 09-18-2010 08:54 PM
Is this box even possible to make? Pictures! BassikInstincts Enclosure Discussion & Design Construction Help 39 01-06-2009 06:39 PM
