Feedback on Design please - Car Audio Classifieds!
Old 08-13-2012, 10:46 PM
0/11 sssss3842
Default Feedback on Design please
been working on this design for 3 Earthquake DBXi-12 (2.5" coil version).
Subs up, port rear firing out of the bottom of rear wall of box. vehicle is a subaru hatch wagon
93 Ford Explorer
4 SA12s
2 saz 1500Dv1 strapped @ 1ohm
saz 100.4
4 sets of IA components
Mechman 260a Alt
Custom door panels
Old 08-13-2012, 11:25 PM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
Should be good with that. Personally I'd go for an upright port on drivers side or expand the height and shrink the width a bit on the one you've got, it's fairly slim. 17.25w x 4h would be better.
Old 08-14-2012, 01:14 AM
^^Agreed. 1:8 port ratio is a bit thin. Other then that it looks great. Report back on those subs, I'm interested to see what you can get out of them.
Old 08-14-2012, 05:26 AM
0/11 sssss3842
Ok thanks. There not mine but it's for a local guy. These are replacing
2 12" Type Rs in a prefab. Gonna be ran on low power for a bit and hopefully owner can find another sundown 1000 to strap.
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 08-14-2012, 06:18 AM
0/11 sssss3842
Quick question: if I wanted to add 45s in the 4 corners how much displacement would the make up and what's the normal dimensions of a 45?
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 08-14-2012, 06:27 AM
mega fatty
0/11 sssss6008
I 2nd the port
1:8 port Hight to width is on the edge some say it should be 1:6
But 45's if you do 1 of them will take up 1/2 of LxWxH
So 4 would take up 2x (LxWxH)
And 45's can be as small or as large as you want they are a great way to add strength, shrink a box that's too big, and help air flow at times
07 mazdaspeed3
rd d9 @ .5ohm
Old 08-14-2012, 06:31 AM
0/11 sssss3842
Originally Posted by tymoto21 View Post
I 2nd the port
I kinda feel stupid for asking about displacement lol. Brains just not working this early for me lol.
So best bet is to put 45s in the 4 vertical corners correct?
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Old 08-14-2012, 07:10 AM
mega fatty
0/11 sssss6008
That does help
It probably would help more to put them on the longer horizontal way but it's up to you
07 mazdaspeed3
rd d9 @ .5ohm
Old 08-14-2012, 07:14 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Most likely .181 displacement ( Here's a site you can use for calculating the displacement: Enclosure Volume Calculator (EVC) ) <---Scroll all the way to the bottom after calculating your corners and put it into the converter. Then put it in the bracing tab in Torres.
I can explain in further details if you are confused about it.
My opinion on the box: Port area is too low *I like to keep my port area b/w 14~16*, Port ratio is way too big. (Made one similar to that, cept it was 1:9...did fine for 8 12" subs...but it has to be rebuild soon) won't ever make that mistake again.
my package is on here somehwere... someone find it lol
yeeeahhh.
Im banning you now...
Old 08-14-2012, 03:29 PM
0/11 sssss3842
look better?
93 Ford Explorer
4 SA12s
saz 100.4
Mechman 260a Alt
Custom door panels
Design Feedback 2 Zv3's justchill0ut Enclosure Discussion & Design Construction Help 9 09-20-2012 01:27 PM
Question about feedback and feedback threads? tRidiot Announcements - Suggestions - Feedback - Support 5 03-06-2011 12:04 PM
need some feedback luises14 General Car Audio Discussion & Questions 9 06-18-2010 01:47 PM
feedback how to? ChampagneCavalierTT Announcements - Suggestions - Feedback - Support 1 07-23-2009 07:22 AM
