Solo x 18 in a single cab - Car Audio Classifieds!
Old 08-15-2012, 01:27 PM
0/11 sssssss48
Default Solo x 18 in a single cab
Ok now that i got your attention, Im wanting to do a single solo x 18 in a single cab s10 in a blow through, trucks already cut im looking for some one familiar with blow throughs, My problem is solo x 18 is to tall so i know i will have to slant sub to get it in. then create a box inside a box and port it through to the cab so i dont loose pressure , is there a rule of thumb on how close the sub can be to the wall or a ratio of size for the sub air space and the box where it will be sealed to the truck. an idea ive been working on is a box designed simular as a jl audio ho box the port the width of the box unfolding acting as the walls of the enlosure braced internally , i know this will be big heavy and exspensive , but this is what i want cause i told it couldnt be done, just looking for some expertise in the subject
Old 08-20-2012, 09:43 AM
0/11 sssssss48
Ok an update, a little more info maybe some can help... I picked up a solo x 18 i got a new spair coming in dual 4 ohm and picked up a ma audio hk 4000d and 9 sheets of 3/4 mdf i'm almost ready to start building
Old 08-20-2012, 09:52 AM
0/11 sssssss69
I hope this is a blowthrough....
Old 08-20-2012, 10:13 AM
wickedwitt's Avatar
Stupid Loud
0/11 sssss2394
Originally Posted by C-LOS View Post
...single cab s10 in a blow through, trucks already cut im looking for some one familiar with blow throughs...
Reading>you
Sounds like fun. I have no experience w/ blow throughs C-Los, but I do have decent info on the X. With 4000, I would do my best to stick with about 7.5 cu. after displacement and give it plenty of port. Always be mindful of the X as even though the motor is a monster, the soft parts do not warrant putting much over 3500 on them daily. Keep the power clean and the sub from bottoming out and you will thoroughly enjoy this build.
Stupid Loud.
Old 08-20-2012, 10:20 AM
its_ray_ray's Avatar
OCD Member
1/11 sssss5696
Feedback Score: 23 reviews
And careful on that amp too lol
Old 08-20-2012, 10:21 AM
0/11 sssssss69
wtf?? the first post didnt show up?? I was like, "an update for what" but now I get it. should be cool
Old 08-20-2012, 10:22 AM
wickedwitt's Avatar
Stupid Loud
0/11 sssss2394
LOL server lag. I apologize for calling you out. It sucks to not see a post and make a comment that makes you look foolish.
Stupid Loud.
Old 08-20-2012, 10:23 AM
TEAM 6HZ UNDER
0/11 sssss2020
are you planning on a foruth order or a 6th order?
1998 Grand Cherokee 5.9 - Sony HU, Stock Infinity Mids/Highs (for now), OA18 v2, AP mini 1500 (fight me)
We all on here were newbs at one point in our life thats what alot of ppl seem to forget its about the love of bass at the end of the day
Old 08-20-2012, 10:43 AM
mega fatty
0/11 sssss6008
From the sound of it you want to try a standard ported box. So make the cutout as large as possible to not affect the sub or port in any way and mount the sub and port as close to the opening as possible without touching or chocking the sub or port.
And don't make the port the width of the box that will not work good. I would start with a vertical slot port and make it decently wide as you can always shrink the port.
Or you can do a 6th order and not worry about the cutout but give up your bed
07 mazdaspeed3
rd d9 @ .5ohm
Old 08-20-2012, 12:56 PM
0/11 sssssss48
yes its gonna be a blow through, i have 3 red top bats going in now till i get my yellow tops in im gonna run truck on one red top and the amps on 4 yellow tops , i did the big three this past weekend and im gonna run a few runs of 00 gauge today depending on the weather i couldnt get the pic of the box design to load im on a work computer so having trouble
Tags
solo x
Single cab F-150 crackills Build Logs 22 02-24-2013 07:51 PM
04 Sierra single cab Calebjcline Build Logs 207 11-20-2012 01:03 PM
2 SA 10's in a single cab Miles Enclosure Discussion & Design Construction Help 12 10-04-2011 03:59 PM
single cab bass? xkryptonitex General Car Audio Discussion & Questions 15 08-01-2010 12:11 AM
Loud Single Cab? null_void General Car Audio Discussion & Questions 32 03-11-2009 02:48 AM
