front plate help - Car Audio Classifieds!
Old 08-20-2012, 09:21 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
Smile front plate help
is some one good at sketchup or another program? i need some one to plot out 4-15''s and a 10'' id port(od of port flare is 12", i can cut if needed) but the front plate is 27" tall and 48" wide, can some one do this for me?? i need help getting it done! my email is [email protected], thank you in advance!
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
Old 08-20-2012, 09:48 PM
0/11 sssss1813
or is this not possible??
4xSundown sa-8''s
Old 08-21-2012, 12:25 AM
That's going to be tight. When it comes to things like that I'm kind of old fashioned. I use a tape measure and mark off a part of my floor with painters tape and then find something the size of the subs/port (plates/skillets/lids/etc.) to lay it all out, lol. I'm assuming you don't have the equipment on hand?
Old 08-21-2012, 05:53 AM
0/11 sssss1813
Exactly lol. I also don't wanna start building if it won't fit, so I need to make sure it will, but I'm no good at using and tool like sketch up
4xSundown sa-8''s
Old 08-21-2012, 06:30 AM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
If the subs are 15.5OD, then it will just barely fit. But you'll have to shave about 1/8" off the port flare to make it fit under the top right hand sub.
Old 08-21-2012, 06:37 AM
newarkbeast973's Avatar
0/11 sssss7810
Would that be enough space between subs?
That's tighter than a virgin right there!!
New build coming soon!!
Old 08-21-2012, 07:36 AM
666WMD's Avatar
0/11 sssss1307
He could shuffle them over so the right hand one was on the edge, would give him more space between them. The port would have to be dropped down and the edges shaved a half inch or so.
Old 08-21-2012, 07:49 AM
0/11 sssss1813
I can cut the port, is there any way I can make it so the port is in the middle on the top and subs around? The subs are sa15"s
4xSundown sa-8''s
Old 08-21-2012, 08:18 AM
0/11 sssss1813
And to be precise, the od of each sub is 15 3/8"
4xSundown sa-8''s
Old 08-21-2012, 09:13 AM
666WMD's Avatar
0/11 sssss1307
You could have the port in any of the 4 corners but that configuration I showed is the only way you will fit 4 15's on a flat surface, so no, you can't have the port in the middle.
Hide a plate motorized license plate remote controlled bigdhenderson Miscellaneous Stuff For Sale 13 04-12-2012 08:31 PM
Dc audio plate Rd4me Speaker Accessories & Parts 25 11-11-2010 09:45 PM
front license plate davidrforbus General Car Audio Discussion & Questions 10 05-28-2010 02:32 AM
New Plate Wanna-B-Basshead Off Topic Chat 37 02-02-2010 10:28 PM
Plate Amp for H.T. snb778 General Home Audio/Video 11 12-02-2009 11:12 AM
