POWER HX2 12" trunkbox tips - Car Audio Classifieds!
Old 08-21-2012, 10:35 PM
Big jcc's Avatar
0/11 sssss1178
Feedback Score: 47 reviews
Default POWER HX2 12" trunkbox tips
I have pulled specs from RF, rec, 1.75-4 ^ but recommend 2.0^ tuned @ 35hz with 4" round port 10" long...just seamed out dated..does anybody know a better port ideal...slot,areo,..i was thinking 5" areo..what do you guys think...thanks
Big jcc
Old 08-22-2012, 08:46 PM
Big jcc's Avatar
0/11 sssss1178
Does anybody have any suggestion for a box for a HX2??.
Old 08-31-2012, 10:38 PM
0/11 sssss1364
Feedback Score: 25 reviews
talk to oldschoolrf or djpotmeter they will know
97 civic ex new build coming soon. head unit poineer premier 80prs fronts/rears diamond audio hex pros mid & high stage amp Diamond Audio HEX 700.4 sub amp diamond audio d6 1500.1 coming sub stage 1 diamond audio d9 15d2 lwire stinger zero gauge & 4 gauge 1 c&d 102ah batts, kenitik 800,200 amp alt mechman
Old 08-31-2012, 10:58 PM
Colbyjack's Avatar
My Tralala. You touch it
0/11 ssssss391
I had a punch hx2 12 in a trunk with sub up port to drivers side that sounded great.
40"w X 18"d X 11"h (outside specs)
Port was 4"w X 9"h X 23"L
Tuned a little high, I think around 36hz or so. Sounded great though. Was a little lacking on the low end though. After displacement around 2.81 or so.
Goood God! Its bigger than my weiner! Trades?
Obviously. But finding 4hp motors is more difficult than finding 25 year old non-christian virgins.
Have you ever wondered if your mom gave your dad **** right before she kissed you goodnight? You are now.
Old 08-31-2012, 11:01 PM
0/11 sssss1364
really? there is a huge difference for them punch to power series sub....
Old 08-31-2012, 11:07 PM
SQLAudio's Avatar
0/11 sssssss42
The main difference between the Power and Punch series is the power handling. They have the same box requirements. I have two Punch HX2 12's, I have them each in a 2.5 cubic foot enclosure tuned to 30Hz and it sounds great. Here is a link to the box I built for them
HX2 12's in my S10 Blazer
Old 08-31-2012, 11:13 PM
Big jcc's Avatar
0/11 sssss1178
thanks guys for the input, I went ol'school on this bish, started buiding boxs then started playing with the lenths of port."i started with a box calculator to get me close" an im on my 5th box an im at 2.89 cubes with 4" areo thats 11.5" long...for me an the way i like my tunes it sounds good, gets low, an when the kick drum drops you feel deep inside...lol..thanks again guys..oh the box is tuned around 29hz, depends on what calculator you use, dont know for sure, but it works
The Following User Says Thank You to Big jcc For This Useful Post:
Raptor660 (09-01-2012)
Old 09-01-2012, 06:19 PM
SQLAudio's Avatar
0/11 sssssss42
Do you get any port noise with the 4" aero? I built a test box using Rockford's specs and used a 4" round port and got port noise even at low volume. I didn't round off the corners, I just wanted to see how that box would sound.
Old 09-02-2012, 08:16 PM
Big jcc's Avatar
0/11 sssss1178
Default port
There is a little port noise at high volumes, but you have to block everthing out an focus on hearing just port noise, everthing was rounded or 45^ inside the box........Did you use pvc, or aero type port?
Old 09-02-2012, 08:40 PM
SQLAudio's Avatar
0/11 sssssss42
For my test box I just used 4" PVC, I didn't round off the edges or put any 45's in the inside corners. I just threw a box together real quick just to see how well the recommended box would do. I did use a slot port on the box that I use in the truck. I rounded off the edges on the port at both ends and on the braces inside the box.
WTB 15" hx2 power basket,any hx2 power motor RaAudio Wanting to Buy (WTB) 13 02-05-2013 11:31 AM
18" power hx2 cone, 18" punch hx2 basket, TRF dustcap Novicaine Speaker Accessories & Parts 6 08-11-2012 05:28 AM
RF Power HX2 15" TeamPSI (Fix My Speaker) 11 01-30-2011 07:58 PM
WTB motors- Type R 15" RF HX2 Power/ Power DVC Forevrbumpn Wanting to Buy (WTB) 13 08-24-2010 07:15 PM
