flex of 1/2" lexan vs 3/4" mdf - Car Audio Classifieds!
Old 08-22-2012, 12:43 AM
GiGLZ's Avatar
0/11 ssssss514
Default flex of 1/2" lexan vs 3/4" mdf
gonna be using 1/2" lexan for the first time and was wondering if i should worry about flex? windows will be 10"x10" & 15.5"x20" mounted over 3/4" mdf with a 8"x8" & 13.5"x18" opening.
thanks
Burt
Old 08-22-2012, 01:33 AM
0/11 sssss2011
Feedback Score: 61 reviews
lexan or plexi, i'd use 3/4" over 1" or 1.5" mdf. either way with the 10" x 10" window you should be fine but not too sure about the other window. if you are going to use 1/2" i'd look into some sort of bracing near the center of the longest run.
Old 08-22-2012, 01:46 AM
GiGLZ's Avatar
0/11 ssssss514
the larger window is designed for install an removal of my 15" monster. ill have to figure out how to brace the larger window after i guess unless anyone else has any suggestions.. i could double up the lexan possibly.
Old 08-24-2012, 03:35 AM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
i got some 1/2" lexan from a guy that used to work building jail cells, I used a piece in a box with 2 aq 15's, about 14" x 20" and it was fine.
2 FI bl 18's walled in 2012 scion xb
The Following User Says Thank You to 98Expo For This Useful Post:
GiGLZ (08-24-2012)
Old 08-24-2012, 04:07 AM
GiGLZ's Avatar
0/11 ssssss514
great! thank you!
Burt
Old 08-24-2012, 04:48 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
isn't 1/2" lexan retarded expensive? especially that big?
Current Build:
#60sHereIcome
Old 08-24-2012, 07:00 AM
GiGLZ's Avatar
0/11 ssssss514
yup. stupid expensive
Old 08-24-2012, 07:01 AM
GiGLZ's Avatar
0/11 ssssss514
dash kits, 6.5" grillz, 4" aero, ANL's, 6.5" MDF ringz, 3/0 reducers +more 18inchjeepin Wiring, Electrical & Other Installation Equipment 9 07-23-2011 08:46 PM
wtb: clear lexan or plexi at least 3/4" thick mikeyg402 Miscellaneous Stuff For Sale 2 07-23-2010 02:45 AM
WTB: MDF 8" and 6" flush mount speaker rings _AnGeL_ Wanting to Buy (WTB) 4 07-14-2009 11:16 AM
[SOLD]1/2" Lexan (Plexi) civicman07 Wiring, Electrical & Other Installation Equipment 41 03-16-2009 09:02 PM
